RV.Net Open Roads Forum: Dinghy Towing: Plug and play wiring harness for Jeep
Search only in Dinghy Towing
 > Plug and play wiring harness for Jeep
FLHTCI
east coast
Posted: 10/26/21 10:55am Link  |  Quote  |  Print  |  Notify Moderator
Hello again, I’ve ordered all the components I need to tow my 2013 Jeep Wrangler behind my motor home expect the wiring harness that will power my brake and turn signals.
I find the description vague. What brand do you suggest?
Thank you
2012 Winnebago Itasca Class A Sunstar 30T
2013 Jeep Sahara (JKU)
2012 Harley Davidson FLHTCUTG
2012 Ford F-250
Trigger Happy
So. Calif.
Posted: 10/26/21 11:26am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I've been using Roadmaster light kit, tow bar and air brake system for many years. Never any problems with either.
Factory customer service always answers the phone and very helpful with any of my questions. 800-669-9690
Enjoy and travel save!
2012 Discovery 40X 380hp ISC.
Toad is a 2014 Jeep Wrangler JK
Y-Guy
Tri-Cities, WA
Posted: 10/26/21 12:45pm Link  |  Quote  |  Print  |  Notify Moderator
I setup my Jeep this summer, but will be adding the CoolTech JK Tow Harness Kit as I think it's the easiest to install without any wire cutting or diodes to deal with.
2007 Winnebago Sightseer 35J
2011 Jeep Wrangler
Thunder Mountain
Lost in the Four Corners
Posted: 10/26/21 12:56pm Link  |  Quote  |  Print  |  Notify Moderator
What he said. I've installed three CoolTech harnesses. The latest was on my 2018 Rubicon. It was more involved since it has the new LED lighting. The 2013 was very easy. Good instructions. Just follow them.
2016 Winnebago Journey 40R
2018 Rubicon
1982 FJ40 Toyota Land Cruiser
2020 Keystone Outback 327CG
2020 Dodge Ram 2500
Polaris RZR XP 1000
4 Cats
3 Dogs
1 Bottle of Jack Daniels
Two old hippies still trying to find ourselves!
Y-Guy
Tri-Cities, WA
Posted: 10/26/21 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Thunder Mountain and you bring up a good point, the install on the new JL is what scared me away, plus the JK version was out of stock as I recall. Now I wish I'd waited vs using the magnetic lights I used for my 1st trip.
Thunder Mountain
Posted: 10/26/21 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
Is some respects the new JL kit was easier in than the JK kit since you didn't have to route the wires through the frame to the back taillights. On the JL you have to pull the passenger door sill and assorted pieces. Then you have to find the four correct wires in the factory bundle (there must be at least 30-40 color coded wires), snip those four wires and connect the CoolTech harness. You test it through the process to make sure you found the correct wires. My only problem was my lack of attention that let me connect the umbilical plug wrong.
Posted: 10/26/21 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
BOth Roadmaster and Blue Ox as I recall sell "Plug and play"
To install generally there is a plug under the dash already in a matching socket
You unplug and plug the module into the socket and the plug into the module.
Then you route the line up to the front and plug it into the module. as Porkey would say Th-Th-Th-Th-That's all folks.
The "Magic" is in the module (A pack of diodes).
chuckftboy
Fleming Island, Florida
Posted: 10/26/21 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
You could use the Mopar 82216358AA wire harness made by the manufacturer.
2019 Horizon 42Q Maxim Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
Y-Guy
Tri-Cities, WA
Posted: 10/27/21 07:32am Link  |  Quote  |  Print  |  Notify Moderator
You could, but at $450-500? There are much cheaper options.
Thunder Mountain
Posted: 10/27/21 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
CoolTech $175 delivered.
