jerryleejr
TN
Punched in the VIN of a truck I’m looking at. It lists the GVWR as 11,400 However the door sticker says GVWR 12,300.
Any ideas? It’s a Ram 3500 mega cab
PICS
toedtoes
California
I would go by the door sticker.
Truck weights have changed significantly over the past several years and the VIN format has not been updated to account for it. A 150/1500 pickup will now weigh 12,300lbs, but the VIN format still only accounts for a max gvwr of 11,400lbs for a 150/1500 model.
So the manufacturers (Dodge is the most common for "overweight" pickups) use the max gvwr of 11,400lbs when establishing the VIN, but put the actual gvwr on the sticker.
I dealt with this a lot at work because our vehicle database pulled from the VIN and the gvwr was wrong more often than right.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
Kayteg1
California > Nevada
I would call the dealer to clarify.
Both numbers are taxable data, having very loose connection to actual truck capabilities.
For TC purpose, the rear 7000 lb capability is what really counts.
jerryleejr
TN
Kayteg1 wrote: I would call the dealer to clarify.
Yeah just thought it was odd, even building one on rams website will allow a SRW or DRW with a 12,3000 GVWR. Of course 14K GVWR is also an option.
JJ
kohldad
Goose Creek, SC
For 2015, the year of my truck: SRW gasser has a 11,400 GVWR. SRW Diesel has a 12,300 GVWR. They add 900# to the GVWR to compensate for the extra weight of the diesel so the payload capacity of each truck is almost identical. However, the VIN on the build site should match the door sticker.
One thought is that the build will list two GVWR. The 11,300# for the basic truck configuration and then the 12,300# for the optional diesel.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
jimh406
Western MT
My guess is RAM has a problem with the computer software that prints the door sticker or the wrong one was put on at the factory. The VIN should include all options. That’s one of the points of it.
srschang
Western NY
My guess is Ram adds heavier springs and shocks on the front end to compensate for the added weight of the diesel. So the heavier GVWR would be correct.
2020 Ram 3500 SRW Crewcab Longbed Cummins, 2019 Northstar 12 STC
I totally don't understand what you wrote.
2017 Heartland Torque T29
Pete_k
Stantonville Tn
Just input the vin into this and see what it shows.
https://www.ramtrucks.com/towing/towing-guide.html
2022 Ram Big Horn DRW
2016 Eagle Cap 1200
2012 Landmark Key Largo
2005 Chevy Kodiak c5500 Cummins 5.9/Allison Trans
JIMNLIN
Oklahoma
I google news around 5:30-6 am every morning. Several days back I read where some vehicles had the wrong door tag gvwr assigned and advise was to check with the vehicle mfg/dealer for them to issue the correct sticker.
I would say the vin is correct.
