RV.Net Open Roads Forum: Class A Motorhomes: Safety steer
 > Safety steer
bennefim
Daleville, AL
Posted: 11/21/21 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry, mileage on shocks/springs are at 59,000 miles.
Doug
Gjac
Milford, CT
Posted: 11/22/21 08:15am Link  |  Quote  |  Print  |  Notify Moderator
At 60k miles I would replace the shocks and get an alignment and getting the caster right. Do the yellow bumpers touch the springs or is there a gap between them? A good alignment shop can check your ride height as well as sagging or worn springs and other components for wear.
bennefim
Daleville, AL
Posted: 11/23/21 07:47am Link  |  Quote  |  Print  |  Notify Moderator
Thanks Grace. Will follow your advice and see how it works.
Doug
rgatijnet1
Posted: 11/23/21 09:25am Link  |  Quote  |  Print  |  Notify Moderator
Doug,
What you suspect is Sumo spring is actually the stock factory bumpers that come with a Workhorse "W" chassis. They come in different colors depending on the axle weight. IN addition to your front end alignment as recommended, you may want to consider a thrust angle alignment that insures that your rear axle is in perfect alignment with the front axle. I am sure that you have seen vehicles going down the road looking like they are "crabbing". A front end only alignment will not correct this. The problem is that most truck alignment shops cannot do this so you will have to search for one that has the proper equipment.
s N s
Michigan / Florida
Posted: 11/24/21 03:19am Link  |  Quote  |  Print  |  Notify Moderator
Our 04 W22 was situated with probably the heaviest gas coach built being a Newmar Mountain Aire. Never had one problem with it going down the road and it was bone stock. I think a lot of these modification needs are in ones head. Air the tires up correctly and you should be good to go. JMHO
Steve & Sally
Hudson (Our Little Pom)
HiTee, Houston & Heidi (Forever In Our Hearts and Never Forgotten)
04 NEWMAR MACA 3778 W22
05 pt Cruiser Vert 5 speed
Demco baseplate with Commander Tow Bar
"Never try to outsmart your common sense"
 > Safety steer
