RV.Net Open Roads Forum: Minor alignment issue... but a long story
 > Minor alignment issue... but a long story
Desert Captain
Payson
Posted: 02/03/22 08:46am Link  |  Quote  |  Print  |  Notify Moderator
"I read somewhere that after cleaning up the rust on the battery tray it can be sprayed with the truck bed coating from Harbor Freight. I actually bought the under coating instead and used it on mine. "
Great idea, thanks. Now I have another excuse to head down to HF.
Ron, I agree a long ride across a strong side wind could generate that sort of wear. Our previous trip was a 2 weeks in southern California which had a fair amount of interstate crossing the desert but I will never know if that was the case. The alignment found a slight toe in correction was needed but everything g else was set to spec... not too bad after 8 years and 63,000+ miles.
[emoticon]
W21q
Guadalupe
Posted: 06/17/22 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
Hello. Generally ABS brakes 2009 Toyota Camry ABS Pump Control Module are unnecessary, and a complete failure of the system is meaningless. Data over many years doesn’t show them as adding much of anything to safety. If you have any driving experience in slick road conditions, they serve little purpose for you, and you can pump the brakes to control skids yourself. ABS brakes 2009 Toyota Camry ABS Pump Control Module
* This post was edited 06/23/22 08:30am by W21q *
