RV.Net Open Roads Forum: Travel Trailers: Bought our trailer, now come the questions!
 > Bought our trailer, now come the questions!
mkenyon2
Lebanon, PA
Posted: 10/30/21 01:16pm Link  |  Quote  |  Print  |  Notify Moderator
We feel we did a good deal of research and are pretty happy with our trailer overall. I have a few questions about QOL (Quality of Life) with it, minor things.
First, the light switch gets very warm. Is that normal? Anything to look into or worry about? (Pics below, light diffuser removed for the picture.)
Also, the main door latch closes hard. Is there a good grease for that? (Another image below.)
Other than that, no major questions or concerns! We're quite excited for our first trip with it.
MK and my Wifey from PA
TV: 2011 Ford F150 SuperCrew 4WD (V6 3.5L/213)
Trailer: 2013 Heartland Trail Runner 25 SLE
We've only camped in 2 states? Quick, pack the trailer we have to CAMP!
Gdetrailer
PA
Posted: 10/30/21 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
Incadescent bulbs draw a lot of wattage which with enough load can cause switches to get "warm" but not hot to touch.
Someone could have replaced the original bulb with a bulb that draws a higher wattage for more brightness which could be bad.
May wish to consider finding LED replacement bulbs to fit your fixtures.
Hard closing doors are sometimes caused by misalignment of the door, warped, rotted door or worn hinges causing the latch to not engage correctly in the frame.
Verify the latch is centering with mating latch surface in the the door frame correctly and that the door is not warped, tweeked or rotted out.
MFL
Midwest
You show a pic of actual switch, and then the light fixture? The switch should not get VERY warm, but the fixture/bulb will.
I have used a slight amount of clear teflon trailer ball lubricant on my door strike and latch pictured. Works very easy for a long time. I don't just wing/slam the door shut, most times, just push it shut, often times using the pull handle when doing so. RV doors aren't built like a truck door.
Jerry
mkenyon2
Lebanon, PA
Posted: 10/30/21 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
Ah, thanks for the thoughts.
Yeah, it's the switch I noticed that gets warm. And quite possibly wrong wattage bulbs. I'll check that.
And the door seems to line up fine, except the strike and latch. I need to pull the handle (pulling in the latch) to get it to close smooth. I'll look a bit closer, and maybe try the lube you recommended. Thanks.
Gdetrailer
PA
Posted: 10/30/21 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
Latch assy may need a little light lubrication on the edges (top/bottom, sides), adding lubrication to the gliding surface of the latch is pretty much futile as it will just wear off or end up on your hands and clothes over time and the issue just comes back until you relubricate.
I have never lubricated the gliding surface of my latches on my current TT and they work perfectly. Wasn't the case with the original doors on my current TT as they were totally destroyed by water damage and sagging.. I built new doors from scratch, no more latching issues..
Not saying your doors are toast, just saying that a little sag or misadjustment in the door can be a real drag on the latch.
Have you tried the doors with stabilizers down to see if that makes a difference?
Sometimes overtightening the stabilizers can temporarily tweek the trailer frame enough to cause the doors to stick or be difficult to open or close.
jdgreen42
Silsbee, TX 77656
Posted: 10/30/21 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
Bar soap or parafin decorative candle, etc will work on the door latch. It will wear off, just re-apply.
Don
Gdetrailer
PA
Posted: 10/30/21 02:45pm Link  |  Quote  |  Print  |  Notify Moderator
Paraffin or candle wax..
Good call, one of my "go to's" for fixing sticking or difficult operating zippers.
Dry, natural and if you brush or touch it doesn't leave a grimy/dirty mess plus does not attract or hold dust and dirt.
Have used candle wax on sticking RV window slides.
Take any candle, rub the candle on the surface you want to be dry lubricated..
Might work for a time in the case of the latch surface but will eventually need to be reapplied..
WayneAt63044
St. Louis, MO
Posted: 10/30/21 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
When my latch gets hard to operate I pull the handle to bring the latch into the door and give it a quick spray of WD-40. That lubes the internal sliding surfaces of the latch. I then release it and wipe off excess to keep from soiling clothes. Good for a month or two.
2012 Forest River V-Cross Vibe 826VFK
pulled by 2009 Ram 1500 Quad Cab Hemi
CA Traveler
The Western States
Posted: 10/30/21 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
Wall switch should not get warm. Light switch can get warm due to the bulbs. Replace bulbs with LEDs. Available in different light color to suit you.
Door: Adjustment maybe. Use silicon lube because it doesn't attract dirt unlike oil/grease.
2014 Grand Cherokee Overland
Bob
CA Traveler
The Western States
Posted: 10/30/21 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
LEDs are 1/6 the wattage and heat for equivalent light.
