RV.Net Open Roads Forum: Tech Issues: Inexpensive inverters with 1 year warranty
 > Inexpensive inverters with 1 year warranty
pianotuna
Regina, SK, Canada
Posted: 10/30/21 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
Hi all,
I enjoy having a 1000 watt inverter as a back up. Doing so has saved my bacon more than once.
https://voltageconverters.ca/collections........jCHYWKG_yWqR6t3_Ul0uctqTFjH2yEG8Fmb2KTMY
Regards, Don
2oldman
NM
Posted: 10/30/21 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
As a backup, yes, I carry an old Xantrex 1kw. But generally, cheap inverters don't make it more than a few years in regular service - depending on how hard you work them. At least that's been my experience.
MT BOB
Montana
Posted: 10/30/21 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
I carry a cheap one,just in case.
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 10/30/21 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
You need to be careful with small cheap Inverters as the voltage produced probably won't be clean (not a sine wave) and can harm sensitive electronics.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Cambria, California area
Posted: 10/30/21 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
Backup inverter s a good idea.
time2roll
Posted: 10/30/21 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
I have both a 2000w and 300w GoPower inverter in service. No backup. I would not consider either of these value priced.
675w Solar pictures back up
StirCrazy
Kamloops, BC, Canada
Posted: 10/31/21 10:26am Link  |  Quote  |  Print  |  Notify Moderator
I don't use a back up, if my inverter were to pack it in, I would just put away the electric coffe pot and pull out the stove top perculator, same with the toaster, and not watch tv I guess haha.. oh and the outdoor kitchen fridge would stop keeping the pop and beer cold so I would have to move some into the rv fridge.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
pianotuna
Regina, SK, Canada
Posted: 10/31/21 10:36am Link  |  Quote  |  Print  |  Notify Moderator
There is a place for modified sine wave inverters. Some are even rated to run motors.
However, all my inverters are pure sine wave, and I do encourage their use.
2oldman
NM
Posted: 10/31/21 10:43am Link  |  Quote  |  Print  |  Notify Moderator
They also get hot if they're really crappy.
pianotuna
Regina, SK, Canada
Posted: 10/31/21 10:54am Link  |  Quote  |  Print  |  Notify Moderator
2oldman,
So do pure sine wave. So much so that mine caught on fire. Poor design is the cause. The unit is a Magnum hybrid 3000 watt unit.
The typical numbers are 88% efficient. So when pushing to 3000 watts 360 watts of heat are being produced. That's about what my coffee pot draws.
