dogvetia
papillion, nebraska
I have a 2018 cruiser aire. It has a 1/2 inch plex pipe out the bottom to drain fresh water tank. It takes several hours to drain the tank. Would like to sanitize my water system but drains so slow. My motorhome would dump 100 gals in 3 minutes but had much larger slide vale as a dump. Am I doing something wrong to have to wait several hours to drain??
2012 F350 diesel
2018 cruiser lite 28rd
sch911
Rochester Hills, MI
Open the gravity fill cap and see if that helps.
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
2oldman
NM
Run the pump, open the faucets and go out the gray tank.
Owens River area
I agree…run the pump. With a bucket in the kitchen sink and a three pound coffee can in the bathroom it’ll drain quickly.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
enblethen
Moses Lake, WA
I take the adapter pipe fitting out of the tank. That increases the opening. Originally had debris from factory drilling the tank lodged in opening.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
dogvetia
papillion, nebraska
This has the cold weather package which stops all access to the tanks. Also there is no gravity fill just a hose connection. Thanks for ideas. Best may be run thru get. 60gal tank
laknox
Arizona
dogvetia wrote: I have a 2018 cruiser aire. It has a 1/2 inch plex pipe out the bottom to drain fresh water tank. It takes several hours to drain the tank. Would like to sanitize my water system but drains so slow. My motorhome would dump 100 gals in 3 minutes but had much larger slide vale as a dump. Am I doing something wrong to have to wait several hours to drain??
IMO, you probably have trash in the line. I have nearly 60 gal fresh, with the 1/2" drain line, and it takes about 30 minutes to dump a full tank. I wish it had a 1.25" line like my old Komfort did.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 64 Year Member
Cummins12V98
on the road
I have the 100G fresh and it does tale a long time to drain as mentioned it has a 1/2" pex but I guarantee the 1/4 turn valve has an even smaller opening.
No biggie to me as I simply open the valve and when it's done draining I close it. There is a vent hole on my Andersen valve assembly like most any other RV that allows plenty of air into the tank for draining.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
TXiceman
Full Time RVer
For draining the freshwater tank, I just open the gravity fill and the small dump line and let it drain overnight.
Kwne
Amateur Radio Operator.
MT BOB
Montana
I agree, probably restriction in the line, not a rare situation , builders leave garbage in tanks quite a bit. I would try blowing air into the drain,then see if it makes a difference, even for a bit, next time. You could call builder and find proper procedure to gain access.
