RV.Net Open Roads Forum: Technology Corner: Suggestions for Printer/Copier/Scanner for RV
 > Suggestions for Printer/Copier/Scanner for RV
curt12914
Bombay NY (5 miles from Quebec, 15 from Ontario)
Posted: 11/01/21 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
I apologize if this has been discussed before, but I am looking for suggestions for a printer/copier/scanner for our fifth wheel.
We are not anywhere near full timers, but we are planning to snowbird in Florida for about a month (mid February-March). We have reservations in two different parks for a couple weeks each, so we will be using their Wi-Fi along with using our phones as hotspots. I am not sure if we will use the printer/scanner as wireless or if we will use a cable connection.
My Canon Pixma printer at home uses three color and two black ink cartridges. I like that idea rather than throwing a multi color cartridge out when one color has run out.
Size is a consideration, but not a major one. We do have places we can put a mid-sized unit
What are you using and why do you recommend it?
2021 F-350 Platinum 4X4 PSD SRW 2016 Montana 3950FL (2) Honda EU2000i's
...and a few (twenty-some, but other than my wife, no one is counting) antique Allis Chalmers tractors
Y-Guy
Tri-Cities, WA
Posted: 11/01/21 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
I kissed ink cartridges away and bought a Epson EcoTank. I've been very happy with it. But I've never taken it on a trip where it's bouncing around either. But I love that I only need to refill the cartridge that uses the most ink. Costco price was good, size was great about the only downside was the lack of sheet feed scanner, but that was a minor issue that I could have fixed if I bought the next model up.
* This post was edited 11/01/21 08:55pm by Y-Guy *
2007 Winnebago Sightseer 35J
2011 Jeep Wrangler
CA Traveler
The Western States
Posted: 11/01/21 05:57pm Link  |  Quote  |  Print  |  Notify Moderator
We have a Epson XP310 printer due to small size, print/copy/scan and wireless. Laptops and cables don't really work for us. It's not a high end printer. We stopped using color and buy 499inks (cheap) black with everything set to black and white, it does scan in color. It's installed on slide outs in a cabinet, out of sight when not in use. We use our cell Wifi hot spot in the RV and with the home printer, hence it's a one time change on the W10 printer setting between home/RV.
We NEVER use CG WiFi because of obvious security concerns plus many/most have limited speed/performance for a variety of reasons. CG WiFi advertising is often a marketing consideration vs useful.
2014 Grand Cherokee Overland
Bob
rk911
DuPage County
Posted: 11/01/21 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
we"re not fulltiimers either. we carry a small Samsung B&W laser printer. no copy or scan function but size was our primary concern. on the rare occasion when we need to copy or scan something an office supply store, library or even a campground or RV park offfice can usually help with that.
so...consider a laser printer instead of ink. i've found that the laser carts last longer than ink carts.
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
philh
Belleville MI
Posted: 11/01/21 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
def laser. Even at home, I've gone to laser.
RLS7201
Posted: 11/01/21 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
We use an Epson ET2650 EcoTank all in one printer in our MH. No more ink cartridges to break the bank. It was allowed to sit, with out use, for over 6 months. Run it through a couple of head cleanings and it was like new again. Will work WiFi direct to computer or through a router. Nice software package.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
time2roll
Posted: 11/01/21 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Dell color laser 1355cn been working great for must be 15 years with no issues. Not made anymore but I would repurchase something similar today. No way would I go back to liquid ink.
675w Solar pictures back up
NamMedevac 70
Reno
Posted: 11/02/21 01:11am Link  |  Quote  |  Print  |  Notify Moderator
I have always had good experience with HP printers but I don't care for their PCs or laptops and instead use Lenovo and Dell, Acer.
valhalla360
No paticular place.
Posted: 11/02/21 02:35am Link  |  Quote  |  Print  |  Notify Moderator
How often do you print and for what purposes?
We gave up on dragging a printer around and just put it on a thumb drive and take it to officemax or other print place for the rare occasions we need a paper copy of something.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Scottiemom
Posted: 11/02/21 06:19am Link  |  Quote  |  Print  |  Notify Moderator
I have a Macbook Pro and none of my printers would connect to it. So I bought a new printer for home which works great, but I didn't have anything for in the motorhome. I researched what printers would work and I found the HP TangoX.Bought one and it works great.I don't know if it works with other OS's, but it is small and copies, scans and prints.
Dale
Dale Pace
Widow of Terry (Teacher's Pet)
2022 Honda Odyssey
2011 Mazda Miata MX-5
2004 R-Vision Trail-lite 213 (MinnieMee)
Fulltimed for 15 years, now living in Florida
http://www.skoolzoutforever.blogspot.com/
Where are we?
