RV.Net Open Roads Forum: General RVing Issues: Removing old caulk after softening it
 > Removing old caulk after softening it
Brownleaf
Durham
Posted: 11/01/21 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
I am planning on using goo-gone caulk remover to soften old caulk. Anyone have any feedback on that choice and removing old caulk? Thanks Doug
WNYBob
Tonawanda, NY
Posted: 11/01/21 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced my skylight and of course it had lots of Dicor sealant. I removed the sealant with a blade on my oscillating tool. Now my roof is fiberglas, if you material is "rubber" roofing you may damage with this tool.
Brownleaf
Durham
Posted: 11/01/21 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
My roof is fibergl but most dicor seems to be intact. I am working on the side now. While I like the oscl tool I would be nervous about using it on the caulk removal. I will keep it in mind though. Doug
Gary45
Oshawa, Ontario, Canada
Posted: 11/01/21 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
1/2 inch wood chisel works well
12th Man Fan
Flower Mound , Texas
Posted: 11/01/21 08:53pm Link  |  Quote  |  Print  |  Notify Moderator
On hard surfaces I use plastic putty knives.You can use them on rubber roofs also if you are careful.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
Posted: 11/01/21 09:14pm Link  |  Quote  |  Print  |  Notify Moderator
Or peel with a razor blade. I’d try that on smooth surfaces.
2017 Heartland Torque T29
dedmiston
The West
Posted: 11/01/21 09:33pm Link  |  Quote  |  Print  |  Notify Moderator
Yep. Knife or blade.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
NamMedevac 70
Reno
Posted: 11/02/21 01:02am Link  |  Quote  |  Print  |  Notify Moderator
plastic razor blades and/or plastic putty knife works for me after softening with DAP caulk remover on fiberglass.
Cummins12V98
on the road
Posted: 11/02/21 07:23am Link  |  Quote  |  Print  |  Notify Moderator
You may want to add what type of location you are wanting to remove the caulking from.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Cummins12V98
on the road
Posted: 11/02/21 07:25am Link  |  Quote  |  Print  |  Notify Moderator
Interesting how everyone is talking about roof caulking. Did I miss some verbiage in the OP’s post?
* This post was edited 11/02/21 09:58am by Cummins12V98 *
