RV.Net Open Roads Forum: Trouble shooting the cause of Charge Line blown fuse
 > Trouble shooting the cause of Charge Line blown fuse
johnxhc
Temple City
Posted: 11/02/21 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
On my Class A (Ford F53 chassis), if I pushed the brake pedalĀ a few times , the Charge Line fuse blew up, this is repeatable.When that happened, I lost power on Hot and trailer break on 7 way trailer plug
I looked under the RV, the wire for the 7 way trailer plug, everything looked normal and I did not see anything obvious such as damaged wire etc..How do I fix that?
I do have a multi-meter.
Any help will be greatly appreciated.
Thanks in advance.
ArchHoagland
Clovis, CA, USA
Posted: 11/02/21 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
Is there a trailer or toad plugged into that connector when the fuse blows?
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
CA Traveler
The Western States
Posted: 11/02/21 03:30pm Link  |  Quote  |  Print  |  Notify Moderator
If the trailer is attached one possibiliy is that the total amp draw exceeds the fuse, which can be corrected with LEDs. But first measue the amp draw on the brake and charge wire. Have you checked for the correct fuse size? Is the trailer battery good and how do you know?
2014 Grand Cherokee Overland
Bob
enblethen
Moses Lake, WA
Posted: 11/02/21 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
My first thinking is a poor ground connection. My thinking brake operation trying to back feed. Start by checking trailer connectings (umbilical cord bodies) for loose wire.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
YC 1
Yuba City Calif./ Auburndale Florida
Posted: 11/02/21 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
Is this a new problem? That is, was it working at one time?
If it was working then you need to take the connectors apart for an inspection. They often have loose wires that short and chasing that with a voltmeter may be incredibly difficult.
If it only does it with the RV plugged into the truck then inspect the trailer plug closely. I mean take it apart carefully. Heck, a simple screw rattling around inside can drive you crazy.
H/R Endeavor 2008
2013 Ford Edge toad
Full Timers
johnxhc
Temple City
Posted: 11/02/21 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
No, it is not...
johnxhc
Temple City
Posted: 11/02/21 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
No, the trailer is not attached...
it is 30 amps fuse, which is correct size.
no sure what you meant by "trailer battery"..
johnxhc
Temple City
Posted: 11/02/21 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, it was working before.
Ok, I will open the 7 way trailer plug and check.
enblethen
Moses Lake, WA
Posted: 11/02/21 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
If it does it with no trailer connected, problem is in the truck.
CA Traveler
The Western States
Posted: 11/02/21 06:57pm Link  |  Quote  |  Print  |  Notify Moderator
With no trailer attached remove the fuse and reconnect the terminals with a 12V bulb. Then when the light is on then move, tap etc various areas to help isolate the problem. It could be anything that doesn't work including wires. A wire tracer can help and a DC clampon ammeter can help to isolate which connection to the fuse is drawing excessive current.
