RV.Net Open Roads Forum: Does Anyone See A Need For a Portable Generator?
 > Does Anyone See A Need For a Portable Generator?
obiwancanoli
Napa
Posted: 11/02/21 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2017 Class A with an 8K onboard generator. Does anyone see a need to take a portable generator, and if so, would you kindly state your reasons?
I'm thinking I don't need to have this tool along on my adventures, most of which, I expect, will be boondocking hither and yon... and, having recently used a Honda 2K to charge my house batteries (don't ask, long story, not relevant), the small generator was ruined due to the high demands of the coach charging system.
Thanks for your input,
MJ
rexlion
Broken Arrow OK
Posted: 11/02/21 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
Maybe if you felt the need for redundant backup equipment more than you feel the need for the dollars you'd spend? That's the only reason I can think of.
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
pianotuna
Regina, SK, Canada
Posted: 11/02/21 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds as if the 2k generator was not allowed to cool down before it was turned off?
May I ask the size of the battery bank? Chemistry of batteries?
I'd add some solar. 400 to 800 watts.
If there is no inverter, I'd add one of the hybrid's from Victron or Outback.
Regards, Don
valhalla360
No paticular place.
Posted: 11/03/21 01:34am Link  |  Quote  |  Print  |  Notify Moderator
Falls under "penny wise, pound foolish". Yeah, you might burn a little more fuel in the onboard generator but the cost and hassle of a 2nd generator likely far outweighs the extra fuel burn.
As far as the 2000w generator being damaged, that doesn't make much sense. Either it should work or it shouldn't (if it doesn't, it will simply overload and the generator will cut power to the outlet). Nothing should be back feeding to damage the generator.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
gbopp
The Keystone State
Posted: 11/03/21 03:04am Link  |  Quote  |  Print  |  Notify Moderator
If you have an onboard generator that is working as it should, I don't see a need for an additional portable generator.
dodge guy
Bartlett IL
Posted: 11/03/21 04:47am Link  |  Quote  |  Print  |  Notify Moderator
Spend the money on solar, batteries and an inverter.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Ivylog
Blairsville, GA and WPB, FL.
Posted: 11/03/21 05:42am Link  |  Quote  |  Print  |  Notify Moderator
Do you really want gasoline stored in your MH? The best thing you can do for a generator is to use it and at half a gallon/hour, how much fuel are you saving with a portable and are they really quieter for those with delicate hearing?
My generator run time decreased from 2 hour to 1.5 when I installed a residential refrigerator by adding a $200, 100A charger, doubling my charging capacity.
Since then I DIYed 900 W of solar with a payback of 25+ years because the secret of boondocking in the summer (only time we do) is elevation and SHADE so you do not need AC. My generator run time is still over 1 hour…I run it anytime I’m using a high amp appliance.
Sold 04 Dynasty to our son after 14 great years.
Upgraded with a 08 HR Navigator 45’...
way2roll
Wilmington NC
Posted: 11/03/21 06:04am Link  |  Quote  |  Print  |  Notify Moderator
Curious why you think you would need an extra genny. And is there a reason your onboard genny doesn't charge your house batts? And how does charging batteries ruin a stand alone gen?
obiwancanoli
Napa
Posted: 11/03/21 07:14am Link  |  Quote  |  Print  |  Notify Moderator
Thanks, everyone, for your input. As I suspected, there's really no good reason to have an external generator. FWIW, I have 600W solar, 4 LiPo batteries (400Ah), and no, I don't really want to have to store gas for the genny onboard... yes, I agree it's a hassle, that was one reason I posed the question... and I, too, typically run my onboard generator when using a high Amp appliance.
As for the consequences to the external genny, I don't know why it didn't function properly after charging my battery bank... it would start and run briefly, then shut down. Can't tell you if time has healed it, for it belonged to someone else, and he used his all the time for his setup (pull behind trailer, no onboard genny)... thankfully, he had two.
I'll save the external genny for power outages at home...
theoldwizard1
SE MI
Posted: 11/03/21 07:40am Link  |  Quote  |  Print  |  Notify Moderator
Sadly, you learned the hard way ! NEVER use the 12V outlet of a portable generator !! I don't know why they are even on most generators.
