RV.Net Open Roads Forum: Tech Issues: lithium question
 > lithium question
Page of 7
Reisender
NA
Posted: 11/06/21 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
StirCrazy wrote:
Reisender wrote:
StirCrazy wrote:
S Davis wrote:
EVE LifeP04 cells are 10% to 90% for 3500 cycles, they should still have 80% capacity at that point. If so these should outlast me.
I think your missreading that a bit.. the industry standard is that the cycles they list are based off a 100% usage. they recomend 10-90% use range and that will extend your cycle life possibly up to 5000-7000 cycles, before you reach that 80% threshhold. then that 80% could be maintained for another 10 years or longer, if you treat them good.
Steve
Yep. This is why Hertz rent a car is buying 100,000 base models of an EV that uses LFP batteries. An expected battery lifetime of a million kilometres vice other chemistries. You can pretty much run LFP to zero frequently without as much worry of damage. 10 to 90 is much better though. The sacrifice is they are heavier and performance suffers a bit from the higher end models.
We are kicking around the idea of putting something like a battle born in our new little trailer that comes with 2 x 6 volt AGM’s. The cheap skate in me says live with the AGM’s and wait a few more years and the price delta to come down. Guess we’ll see.
haha AGM, up here, are more expensive that some of the new LFP on the market. and if you can hook up a four 6V battery sety up in your camper you can build your own batter setup with prismatic LFP cells which is so much cheeper. Battle born is way over priced now, there trying to hold on to the prices they set when they were only one of 3 competators in the market and I believe they all agreeded on a price range.
Steve
Yep, they are pricey. But am I right? You seem to have a good handle on this. The trailer comes from the factory with 2 x 6!volt AGMs. Would an LFP 31 not be giving up a bit as far as useable amp hours? They are in a heated area so that’s not an issue.
HMS Beagle
Napa, California
Posted: 11/07/21 08:52am Link  |  Quote  |  Print  |  Notify Moderator
To be pedantic, there are almost no EVs with LFP batteries except a few homebuilts. All manufactured EVs use some other lithium chemistry, typically lithium cobalt. LFP (short for Lithium Ferris Phosphate) are less energy dense, but much more fire resistant. I'm just pointing this out because many people will say the lithium batteries are unsafe and burn, just look at the Tesla and Boeing fires, without understanding the difference.
Bigfoot 10.4E, 2015 F350 6.7L DRW 2WD, Autoflex Ultra Air Ride rear suspension, Hellwig Bigwig sway bars front and rear
Reisender
NA
Posted: 11/07/21 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Hmmm. Might be a misunderstanding of terms on my part. I’m not an expert. Presently all the Tesla model 3 SR plus models sold in China and Europe are using LFP batteries. The US made model 3 SR plus (now just called standard range) are available with the LFP battery. They are a little slower and heavier. Presently the LFP battery for these models come from China but the Tesla Nevada will also be building these in the new year.
This is a fairly recent development. All over the last 3 to 9 months depending on factory.
Heads up, all the long range models still use the normal Tesla batteries. They are not LFP. Lithium cobalt etc.
https://www.greencarreports.com/news/113........-3-and-model-y-likely-with-us-production
S Davis
Western WA
Posted: 11/07/21 10:15am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna it really seems you have a vendetta against LifeP04 batteries, I see people limiting their max charge Voltage. I have not tried that yet as I am still building my system.
* This post was edited 11/07/21 11:37am by S Davis *
S Davis
Western WA
Posted: 11/07/21 10:23am Link  |  Quote  |  Print  |  Notify Moderator
Steve
Yes you are correct, that is their recommendation for max cycles. Pulled this from the spec sheet, they consider a cycle from fully charged to 2.5 volt cut off.
A fte r sta nda rd char ged and 30 mins res t, discharge to 2.5V cutoff with the current of 1.0C(A) at (25±2) °C, and then start the next cycle, end with the capacity decrease to 80%
of the initial capacity. The number of cycles is defined as the cycle life of the battery.
* This post was edited 11/07/21 10:41am by S Davis *
pianotuna
Regina, SK, Canada
Posted: 11/07/21 10:40am Link  |  Quote  |  Print  |  Notify Moderator
If you google ice fires--there were 150,000 in USA last year. The fire problem is over blown, and in my opinion, a negative advertising campaign.
The Bolt batteries were defective from the factory that made them. They are replacing them all.
From a seller of LI: https://www.solacity.com/how-to-keep-lifepo4-lithium-ion-batteries-happy/
Regards, Don
3 tons
NV.
Posted: 11/07/21 11:13am Link  |  Quote  |  Print  |  Notify Moderator
Lots of talk about achieving ‘max cycles’ (most anything can ‘and should’ be optimized, eh?), but from my own myopic perspective, with soooo many available charge cycles, I don’t bother much engaging in all that might worry - Were I to lose say 10% of 5,000 LFP charge cycles (due to my own reckless inattentiveness?? lol), I’m still quite happy (in exchange) to enjoy the ‘real-use’ benefits and longevity of LFP…One way or another just about everything in this universe comes with an expiration date, eh - In fact, I’ve yet to learn of anything that gets a waiver [emoticon] !! JMHO
3 tons
time2roll
Posted: 11/07/21 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
3 tons
Yes the whole "maximize life cycles" for LFP is one more hangover from the old lead-acid days because cycles were so few back then.
675w Solar pictures back up
StirCrazy
Kamloops, BC, Canada
Posted: 11/07/21 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
Reisender wrote:
StirCrazy wrote:
Reisender wrote:
Steve
haha AGM, up here, are more expensive that some of the new LFP on the market. and if you can hook up a four 6V battery sety up in your camper you can build your own batter setup with prismatic LFP cells which is so much cheeper. Battle born is way over priced now, there competators in the market and I believe they all agreeded on a price trying to hold on to the prices they set when they were only one of 3 range.
Steve
you could be depends on the exact size of the 6V agms, but we can assume say 180ah??? then a 100 AH LFP would give you the same amount aproximatly of usable , but in a pinch with the 6V you could go down to 20% which means in a emergency you would hve a 144AH capacity. I dont like to size LFP to use the "equivalant" usable AH I like to take advantage of the size and weight and get more AH in a lighter and smaller package. so for me I would realy go with two of thoes batteries, run them nice and take that cycle life through the roof and when you need it you will have a total of 200AH for use in an emergency, but you'll probably never buy another set of batteries in your life.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
AllegroD
Outdare
Posted: 11/07/21 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
No. Just any charger could cause damage. You need to see the mfgr recommendations. Most require a charger that can be set to charge no higher than 14.4.
Page of 7
 > lithium question
