RV.Net Open Roads Forum: Tech Issues: lithium question
 > lithium question
Page of 7
time2roll
Posted: 11/04/21 09:34am Link  |  Quote  |  Print  |  Notify Moderator
MORSNOW wrote:
I can just swap to lithium and keep using the factory WFCO charging system that came installed in my Wolf Creek?
Yes. Although I would recommend 200+ watts solar to go along with the WFCO as I would recommend for any RV camping off-grid.
675w Solar pictures back up
pianotuna
Regina, SK, Canada
Posted: 11/04/21 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
MORSNOW wrote:
Well this thread is an eye opener for me. Everything I remember reading about lithium batteries on here has been saying I need to remove the factory built in charger and install a charger designed for lithium. So now I'm seeing that is not the case, and I can just swap to lithium and keep using the factory WFCO charging system that came installed in my Wolf Creek?
You can. But you won't get the same number of cycles. There are a whole bunch of hoops to jump through if that is the goal.
Regards, Don
HMS Beagle
Napa, California
Posted: 11/04/21 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
Can you use an LA charger for LFP? Yes... Should you? No, at least not without reservations. A well regulated charger should work, but it will depend on the BMS installed in the battery to disconnect if over voltage. That is what they are designed to do, but it is not what they were designed to do in routine charging. Also almost every LFP vendor will tell you not to float charge LFP packs. If the float charge is set low enough, it does no harm. And if you have an LFP battery bank with no BMS, the you are risking damaging the cells and possibly a nice fire.
Bigfoot 10.4E, 2015 F350 6.7L DRW 2WD, Autoflex Ultra Air Ride rear suspension, Hellwig Bigwig sway bars front and rear
time2roll
Posted: 11/04/21 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
I am not sure I understand this statement.
Charging to maybe 95% with 13.6 volts should yield more longevity in a lithium battery.
StirCrazy
Kamloops, BC, Canada
Posted: 11/05/21 06:37am Link  |  Quote  |  Print  |  Notify Moderator
jaycocreek wrote:
I agree Steve except when I got my first Lifepo4 battery I wrote the company and asked which charger will work with your lifepo4..
And this was there answer:
Lynx battery wrote:
Any charger up to 40-50amps that takes either lithium or AGM Batteries.
If you are buying new, go with one with a lithium setting.
But looking at the chart above,Gel is the closest...And I have watched a couple of Will's videos on setting up your solar controller and he mentions for most the lead acid setting will work with lifepo4..Crazy huh...
ya, I have seen a bunch say any will work, but if you dont have Li but do have gell to use that as it is closest. but I think for our purposes with the lower relitive charge amprage we are talking about it wont noticable hurt the battery you might lose a few cycles, but we are talking a few out of 3000 (cant back that up only an asumption as its not getting a perfect charge profile) you may also take longer to charge the batteries but that is just my theory.
for me, if I am spending 400 or more on a lithium battery what another 100 to upgrade the charger section of your power center?
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
jaycocreek
Idaho
Posted: 11/05/21 07:28am Link  |  Quote  |  Print  |  Notify Moderator
I did the same even though Expert Power recommended the Noco genious in a Q&A session...I bought there lifepo4 charger for like $80 and am really happy with it charging at 20 amps instead of the 10 my Noco does..
I was one of the hesitant ones about getting lithium and since I have,I couldn't be happier with charging times and weight..Solar I'm still trying to understand for lithium...
475 ah LFP/600 watts solar
MORSNOW
Mountain Home, ID
Posted: 11/05/21 08:07am Link  |  Quote  |  Print  |  Notify Moderator
bighatnohorse wrote:
Apparently so according to their website: https://wfcoelectronics.com/lithium-solutions/
Thank you!
2014 Wolf Creek 850SB
2012 GMC Sierra SLT 2500HD
7,220# Truck/10,400# Camper Fully Loaded
pianotuna
Regina, SK, Canada
Posted: 11/05/21 08:40am Link  |  Quote  |  Print  |  Notify Moderator
For MAXIMUM cycles charge starting at 40% and stop charging at 90%. How do you manage that with a wfco?
S Davis
Western WA
Posted: 11/05/21 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
EVE LifeP04 cells are 10% to 90% for 3500 cycles, they should still have 80% capacity at that point. If so these should outlast me.
pianotuna
Regina, SK, Canada
Posted: 11/06/21 12:03am Link  |  Quote  |  Print  |  Notify Moderator
S Davis.
Similar question--how do you stop the wfco at 90%?
Page of 7
 > lithium question
