RV.Net Open Roads Forum: Class C Motorhomes: class c with v10
 > class c with v10
thriftydutch
Ontario, Canada
Posted: 11/04/21 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
I'm looking at a class C on a ford chassis with a V10 engine and no big cab over the front. What kind of mileage can i expect on regular country roads while staying at the speed limit.
1990 L.E.R. Dodge B 250 Class B 17'
MDKMDK
Free(er), for now, until the next "variant"
Posted: 11/04/21 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
I'll guess somewhere between 0 mpg and 8 mpg, since the vehicle year/make/model is a secret.
Mike. Comments are anecdotal or personal opinions, and worth what you paid for them.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
bobndot
Posted: 11/04/21 10:42pm Link  |  Quote  |  Print  |  Notify Moderator
My 2018 24' V-10, 8-10 is average. On country roads the hills eat up the gas mileage. At least that's what my scan gauge indicates. Towing the toad or utility trailer eats up an additional 1/2 mpg.
harley-dave
ummm, where are we again..
Posted: 11/05/21 07:44am Link  |  Quote  |  Print  |  Notify Moderator
ya, my 2005 31' C gets 8 - 8 1/2 on level roads at 65 mph, and loses about 1/2 mpg towing the toad. I installed a 5 Star tuner which helped the mileage and shifting on the mountains/hills.
Dave
2005 Winnebago-Itasca Sundancer 31C
2010 Harley-Davidson Soft tail Deluxe
2014 Harley-Davidson Street Glide Special
1999 Chevrolet Tracker 4X4
SKP # 121272
thriftydutch
Ontario, Canada
Posted: 11/05/21 08:02am Link  |  Quote  |  Print  |  Notify Moderator
Sorry about that. It’s a 2006 Ford E450. 25 feet long.
* This post was edited 11/05/21 08:32am by thriftydutch *
ron.dittmer
North-East Illinois
Posted: 11/05/21 11:07am Link  |  Quote  |  Print  |  Notify Moderator
The 2007 E350 chassis is identical to a 2006 E350 chassis. Our motorhome shown below is built on a 2007 Ford E350 chassis with the V10 engine. It's over-all length is 23'-8" and is considered very aerodynamic by motorhome standards. Good aerodynamics helps both with fuel economy and vehicle control.
I advise not to exceed 65 mph on interstates, but 5 mph less at 60 mph is ideal for fuel economy and vehicle control. At 60mph under flat, no-wind conditions, our ScanGauge-II monitor, we see 11.5mph while towing our 2006 Jeep Liberty 4x4, but realistically our trip average of 4000 to 5000 miles of driving, we calculate 9.25mpg. We average 10.5 mpg not towing anything.
A 2006 E450 compared to a 2006 E350 for the same "SHORT" model motorhome, will get roughly ONE MILE PER GALLON LESS because the axle ratio inside the rear differential is geared for a heavier motorhome. The E350 engine rpm will be lower applying less throttle. But as the rig gets heavier, the numbers drift to favor the E450 chassis for the application, including fuel economy. The breaking point between the two is "fluid" due to so many variables including length, aerodynamics, weight, and towing. Also, the E450 frame is a little thicker than the E350, a structural consideration when stretching the wheel base.
Our 2007 Phoenix Cruiser MANY PICTURES HERE is on a 2007 E350 chassis. It has an unmodified, standard 158" wheel base.
* This post was last edited 11/05/21 11:55am by ron.dittmer *   View edit history
2007 Phoenix Cruiser model 2350, with 2006 Jeep Liberty in-tow
theoldwizard1
SE MI
Posted: 11/05/21 04:21pm Link  |  Quote  |  Print  |  Notify Moderator
The V10 has proven durability. As stated, fuel economy not great. Biggest complaint is the engine has to rev up a lot on hills. It can handle it, but it is loud.
T18skyguy
Eugene, OR
Posted: 11/09/21 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
If you get a 2017 and later, you get the 6 speed transmission instead of the 5 speed. Both are good transmissions, but the 6 speed I had was great. As Ron notes above, there is a lot to be said for a wheelbase that's not stretched; fewer driveshafts means less vibration issues, which can be troublesome to correct.
Retired Anesthetist. LTP. Pilot with mechanic/inspection ratings. Between rigs right now.. Wife and daughter. Four cats which we must obey.
pnichols
The Other California
Posted: 11/10/21 11:30am Link  |  Quote  |  Print  |  Notify Moderator
Also, just as side-comments:
1) The Ford E450 chassis comes (or at least used to come) with a larger diameter driveshaft than the E350 driveshaft, for less vibration in any length motorhome.
2) One can easily improve upon any negatives of the E450's higher rear differential ratio by using larger diameter tires on the RV. For instance, most E350/E450 based Class C motorhomes come stock with 225/75R 16 size tires. By changing to 215/85R 16 size tires (which are larger in diameter) you partially or fully compensate for the E450's higher rear differential ratio ... plus as a bonus - improve upon tread wear and increase the distance between the rear duals for better airflow cooling of the tire sidewalls in hot weather.
2005 E450 Itasca 24V Class C
synergy_58
On the road again!
Posted: 12/08/21 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Wow! That’s all these Ford V10’s get for mpg! I didn’t realize they drank so much fuel. I was considering a new one but not anymore, not if that’s all the mp0g I can expect. It’s hard to imagine getting less than what I’m experiencing with my rig.
I have a 2009 Navion, MB diesel Class C. I drive 65-70 and get 14-16 mpg, and my rig stays packed. I average 14.5, lowest I can ever remember is 14.1, towing about 3800 lbs from Anchorage, AK to Pensacola, FL.
2 adults, one very large dog (95 lbs plus dog gear), and our rig was packed.
Yes, I know mine is a diesel, but I dont think a Ford diesel would get much better than the V10.
Oh well, guess I’ll stick with what I have, unless I can find an American badged Class C (or Super C) with a diesel that is comperable with the MB chassis class C’s.
[img/Users/Frank/Pictures/iPhoto Library_2/Originals/2014/Apr 2, 2014/2009_1306_Nav_BlueMoon.jpg[img]
Note: Due to invalid formatting, all formatting has been ignored.
 > class c with v10
