RV.Net Open Roads Forum: Fifth-Wheels: Best truck for large 5th Wheel
 > Best truck for large 5th Wheel
StirCrazy
Kamloops, BC, Canada
Posted: 11/07/21 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
idealy a converted class 8 truck would be the best, and somtimes I wish I went that way myself.
Steve
* This post was edited 11/08/21 06:50pm by StirCrazy *
2014 F350 6.7 Platinum
2016 Cougar 330RBK
Cummins12V98
on the road
Posted: 11/07/21 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
For a 17k 5er?
* This post was edited 11/08/21 07:36am by an administrator/moderator *
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
rhagfo
Portland, OR
Posted: 11/08/21 06:12am Link  |  Quote  |  Print  |  Notify Moderator
I would say not even close to needed! When you see rear axle ratings and tow ratings of the current fleet of 3500/350's most have 5,500# Payloads and Diesel towing capacity around 25,000#.
I would not bat an eye carrying that 5er with our 2016 Ram Laramie 3500 DRW.
It is hard enough to get people accept that they need a DRW to carry a large 5er, let alone a class 7 or class 8 TV!
They want big 5er's, but refuse to the difference between the ablity to carry, and the ablity to pull.
It's too BIG I can't go through the drive through, to hard to park in a parking lot, learn to back in to spaces!
* This post was edited 11/08/21 07:34am by an administrator/moderator *
cummins2014
Utah
Posted: 11/08/21 07:19am Link  |  Quote  |  Print  |  Notify Moderator
For some I am sure it's a want ,not necessarily a need . I entertained the idea at one time .Used was limited ,and a new one was just a bit more then I wanted to pay.
* This post was edited 11/08/21 07:35am by an administrator/moderator *
Cummins12V98
on the road
Posted: 11/08/21 07:21am Link  |  Quote  |  Print  |  Notify Moderator
Yep, “tows just fine” until...........
TXiceman
Full Time RVer
Posted: 11/08/21 07:46am Link  |  Quote  |  Print  |  Notify Moderator
It is real simple folks. They make little trucks for little trailers and BIG trucks for BIG trailers. You need to select your trailer and then buy the appropriate truck to haul it. If you already have the truck, get the trailer that fits it.
We have been driving a DRW long bed F350 as the daily and only driver for about 10 years. You and the missus learn to park it farther out, forget most drive-thru lanes and how to back it.
Every day I see people pull in with a SRW truck and way too much trailer for it. They have to have a short bed SRW to fit in the garage at home or the wife refuses to drive a DRW truck.
Ken
Amateur Radio Operator.
MFL
Midwest
Posted: 11/08/21 08:21am Link  |  Quote  |  Print  |  Notify Moderator
Agree on the want/need! A full time RVer usually needs a large heavy unit, for space/build quality, and may need a DRW/long bed to tow it. Most recreational RVers can tow their choice of RV, with a SRW, and standard bed.
I buy new, to get what I want, and not a lot of options I don't need. I need 4x4, nice seats, want carpet, some electronics.
Jerry
work2much
On the Road
Posted: 11/08/21 09:54am Link  |  Quote  |  Print  |  Notify Moderator
Our Solitude is smaller but we still exceeded the payload rating on a SRW 3500. So dually it is for us.
2022 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2520 watts solar. 600ah lithium. Magnum 4000 watt inverter.
speediq99
Arizona
Posted: 11/08/21 11:16am Link  |  Quote  |  Print  |  Notify Moderator
Thank you for all the feedback. A dually is in out future at some point. It is obvious when 'old timers', respectfully speaking, that have been there done that seem to almost unanimously agree that when it comes to these large 5th wheels, a diesel dually is a must to be safe.
It is now a matter of wrapping our heads around having to use such a big truck and at times big expense for something other than towing a large 5th wheel.
MC
* This post was edited 11/08/21 11:24am by speediq99 *
StirCrazy
Posted: 11/08/21 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
I thought the same but my 5th is 16000K and I pull it with a F350. my paid off, low milage, F250 was to small to legaly carry it by rear axel weight so lets look at the cost. 50000 got me a used f350 and when towing I get about 10Mpg (US) if I would have spent 12-15K on a class 8 that was in deicent shape, had the rear singles (usaly no cost if they keep the mid drive axel) registered it as a RV built a deck and put a light duity air ride 5th hitch I would have been under 20K and what would I have got.
it would get 11 to 13mpg with that weight (assuming you buy the right setup) the seats would be way more comfortable for longer drive. true jake brake and engine brakes means you will hardly have to touch your brakes, the weight of the tractor means the trailer will never push you around as it is about the same weight as the trailer. when empty and runing to get groceries, it turns sharper than any 1 ton on the market so it is easy to manuver in a parking lot. the only disadvantages I can see are biger dogs. you would have to build a way for them to get up there or lift them, and you have to get your airbrake certification (but a class A has to get that also)
one more advantage is you just use it for your 5th wheel so its not a extra expence when your not using it like a normal pick up upgrade would be. in my case yes I would have spent about 15 to 20K but I would still use my f250 as a daily driver, and when I am traveling in the class 8, get better fuel milage. now I had to spend 50K still drive it all the time but get worse fuel milage when traveling.
not saying its for every one, I ended up getting a normal truck, although when I think back I regreat not getting a class 8, as it wouldn't matter what we get when we retire, I would be able to tow it.
Steve
