RV.Net Open Roads Forum: Beginning RVing: Best generator
 > Best generator
Page of 8
Bfrnk
Posted: 11/05/21 09:23pm Link  |  Quote  |  Print  |  Notify Moderator
I'm new at rving but I've researched every site about best or quieter generators and I'm still at odds. What do y'all recommend? My bro in law just ought an Onan but just inot sure!
Skibane
San Antonio, TX
Posted: 11/05/21 09:57pm Link  |  Quote  |  Print  |  Notify Moderator
Onan's portable models are Chinese-made.
There are plenty of other Chinese-made brands - many with comparable specs - most of which are much more affordable.
Price-wise, the sweet spot in inverter generators seems to be the models with roughly 2KW of power output - They seem to offer the best trade-off between cost, noise level, portability and power output. There are hundreds of models available in that size category, including dual-fuel versions that can operate on either gasoline or propane.
Many of them can be connected in tandem ("paralleled"), so that several generators can be used simultaneously to provide more power than one by itself could - very handy for running large roof air conditioners.
For good value, my personal favorite brand is Champion Power Equipment. Their stuff is Chinese-made, but backed by excellent US-based customer support. Most of their models also have a 3 year warranty.
Here's a chart that can be useful in comparing any model under consideration against the rest:
* This post was edited 11/06/21 02:10am by Skibane *
pianotuna
Regina, SK, Canada
Posted: 11/06/21 12:11am Link  |  Quote  |  Print  |  Notify Moderator
If the RV is a 30 amp--then a 2800 watt generator is a great size.
Look at features. Do not buy and open frame generator. They are too noisy. Inverter generators produce excellent clean power.
My Yamaha 3000 sieb does 23.3 amps, which is close to the maximum continuous load. (80% of 30 amps).
I like the Champion 3400 because it comes with remote electric start.
I like the Predator 3500 because it is cheap and has electric start.
Regards, Don
valhalla360
No paticular place.
Posted: 11/06/21 01:35am Link  |  Quote  |  Print  |  Notify Moderator
The best quality is Honda with Yamaha right there with them...but the prices are way beyond the additional quality.
We have a Yamaha and it's served us well but the downside is parts and service aren't commonly available.
As mentioned, Champion seems to be the sweet spot between good quality and good price...ie: the best value.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Skibane
San Antonio, TX
Posted: 11/06/21 02:05am Link  |  Quote  |  Print  |  Notify Moderator
Yes, it is - But it also weighs around 100 pounds.
Most of the 2000 watt models weigh under 50 pounds - which makes them a lot easier to move around.
Incidentally, if you only need a small generator for charging your house batteries or powering small loads - At less than $180, this 800 watt inverter model is a ridiculously good deal.
hondapro
Central Pa
Posted: 11/06/21 05:34am Link  |  Quote  |  Print  |  Notify Moderator
If you want the best quality get the Honda.
Steve
2016 F-350 6.7 Diesel
2015 Springdale 311RE
Tvov
CT
Posted: 11/06/21 06:00am Link  |  Quote  |  Print  |  Notify Moderator
Remember that a small change in "DB level" or noise level is actually big sound-wise - it sounds a lot louder.
2008 F-250 CrewCab 5.4L,
bgum
South Louisiana
Posted: 11/06/21 07:06am Link  |  Quote  |  Print  |  Notify Moderator
Look at Westinghouse igen2500. Good quality, good price. 2500 max watts 2200 running watts. It is an inverter generator quiet and clean electricity. Weight is 48 pounds. Can be found at $500. We have two. Can be combined.
IDman
Oklahoma
Posted: 11/06/21 08:40am Link  |  Quote  |  Print  |  Notify Moderator
We had a Yamaha 2000 for 8-9 years and never had a nickels worth of trouble with it. Sold it to a friend and bought a new Honda 2000 (in the box). It was in the shop after our first use as the tech said it was clogged from stale gas! He said the factory puts some gas in, runs it a bit, and packs and ships them. Some sit for months before being sold. Cost me $70 or so for service as Honda would not honor the warranty.
Wish I had kept my Yamaha.
valhalla360
No paticular place.
Posted: 11/06/21 09:53am Link  |  Quote  |  Print  |  Notify Moderator
It's actually the opposite. dB is a measure of power but to hear a difference in noise level is not linear.
Page of 8
 > Best generator
