RV.Net Open Roads Forum: Furnace flames cycles off before temp is reached
 > Furnace flames cycles off before temp is reached
Chief Bob
Iola, Texas
Posted: 11/07/21 09:27am Link  |  Quote  |  Print  |  Notify Moderator
Thanks all. The furnace is an Atwood. I’m touring bourbon distilleries in Kentucky today so I’ll have to get the model tonight. We should be out of the freezing overnight temperatures for the rest of the trip so hopefully we’ll get by with the heat pumps. I’ll pull things apart and check for obstructions when we get home. I always count on this forum for good advice and direction.
Bob Leiper
Retired Fire Chief & City Manager
Iola, TX
2018 Thor Aria 3401 Diesel Pusher towing a 2021 Ford Escape Hybrid
time2roll
Posted: 11/07/21 09:33am Link  |  Quote  |  Print  |  Notify Moderator
I added two new ducts to increase airflow. Burner cycled about every 3 minutes before, runs continuous now until the thermostat is satisfied. Provides more heat also.
675w Solar pictures back up
Posted: 11/07/21 10:57am Link  |  Quote  |  Print  |  Notify Moderator
^Very helpful.
2017 Heartland Torque T29
JimK-NY
NY
Posted: 11/07/21 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
Mine also runs about 10 minutes, then the flame cuts out for a few minutes and the cycle begins again until finally reaching the temperature set by the thermostat. This is something I hardly notice unless the temperature is cold and I am impatient for the heat.
wildtoad
Blythewood, SC
Posted: 11/07/21 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
Make sure you go by Buffalo Trace.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Chief Bob
Iola, Texas
Posted: 11/07/21 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
The furnace is an Atwood 35,000 btu model AFMD35151.
C Schomer
Pueblo West, Co.
Posted: 11/08/21 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
I'd use a meter and determine what's doing the cycling, first, stat or hi limit. Check the temp rise. I've never had short cycling problems with my RV furnaces but I like to see no more than 70* degrees rise in a res. furnace, when the airflow is really good. Make sure the flex ducts aren't kinked, stat in warm air current, clean the blower wheel, dragging motor, etc... normal checks and maintenance. Craig
Posted: 11/08/21 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
Chief Bob wrote:
Thanks all. I’m touring bourbon distilleries in Kentucky today so I’ll have to get the model tonight .
I wouldn’t be able to read a street sign or type my own name after touring bourbon distilleries!!
Chief Bob
Iola, Texas
Posted: 11/08/21 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
One thing I have been able check on the road is that when the flame short cycles the thermostat is still calling for heat. Thanks
enblethen
Moses Lake, WA
Posted: 11/08/21 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
Could be as easy as a loose connection within the furnace. Heats up and goes open!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
