RV.Net Open Roads Forum: Fifth-Wheels: Pocket door
 > Pocket door
klr650goldwing
minnesota
Posted: 11/07/21 09:27am Link  |  Quote  |  Print  |  Notify Moderator
The bathroom pocket door on our 369RL Solitude has suddenly become loose and positioned at an angle to the way it has been. DW found a 1/2 inch long screw lying on the floor nearby, but we can't find where it came from. When we pull the door out of the wall to close it now, it twists like a parallagram in the doorway opening. Once the door is half-way out, it straightens out. But the initial tug on the open door feels like the door will fall off. Can anyone help us out here. What adjustments are possible here?
2014 Grand Design Solitude 369RL
2017 F350 6.7 DRW CC LB 4X4
2012 Mercedes E550
2010 Honda Civic
2009 Saab 93 Aero Convertible
2004 Honda Goldwing GL1800
2004 Kawasaki KLR650
1966 Honda 305 Dream
noteven
Turtle Island
Posted: 11/07/21 09:38am Link  |  Quote  |  Print  |  Notify Moderator
The pocket door in my trailer is suspended from 2 trucks by a catch on each truck that is attached by screws to the top of the door.
The door can be released from the trucks by moving the catch horizontally allowing the door to drop. I suspect a screw has fallen out from the "back" truck.
The door should be supported by a roller on the floor at the edge of the opening.
It is levelling out on that roller as you close it, but the top is detached on one side.
Release the other catch from its truck and remove the door from the opening and inspect.
At least two pinched fingers must occur getting a RV pocket door out of the opening.
Example of pocket door hardware.
Cummins12V98
on the road
Posted: 11/07/21 02:28pm Link  |  Quote  |  Print  |  Notify Moderator
Your hanging bracket has come loose/unattached. Hope you have an access on one side or another to re attach/connect.
I was a Master at properly hanging pocket doors after having a couple failures in Commercial applications.
I have a love hate relationship with pocket doors!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Dick_B
Palos Heights, IL USA
Posted: 11/08/21 08:03am Link  |  Quote  |  Print  |  Notify Moderator
Seems to me we had this same problem and removed the door to support the track in the closed part of the pocket. We drilled a couple of holes in the track as far back as can be reached and added screws.
The door hanging by a few screws is under stress due to the bouncing of the rv on the bad roads so this is a rather common problem.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
One wife, two electric bikes (both Currie Tech Path+ models)
Cummins12V98
on the road
Posted: 11/08/21 09:33am Link  |  Quote  |  Print  |  Notify Moderator
YES, the track can come loose as the JACK AZZES will use driller screws to attach the track to the header.
klr650goldwing
minnesota
Posted: 11/08/21 09:48am Link  |  Quote  |  Print  |  Notify Moderator
We've now found two screws on the floor down in the pocket area. We think these two screws were used to hold the channel to the ceiling. When the door is fully in the wall/the pocket area and we just begin to close it, the bottom of the door moves first. This is because the full weight of the door is hanging from the channel under the part of the channel where the screws fell out. So not much is holding the door up at that point. So the solution seems to be to remove the door and replace the screws that held the channel to the ceiling. The problem is that I don't think I can get my hand and arm into the pocket opening far enough to replace those screws. Do you all have some good ideas here?
Cummins12V98
on the road
Posted: 11/08/21 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
Door removal is NOT REQUIRED. You need access on one side or the other to add bigger screws.
Wadcutter
IL
Posted: 11/08/21 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
Just replacing the screws will not be a good fix unless you hit a ceiling truss. If you just run screws into the ceiling then they'll just pull out again. The ceiling material is thin and won't hold weight. Most likely you have wooden truss in the ceiling. Could be aluminum. Doesn't matter. First find where the truss crosses the ceiling. That is where you want to run the screw.
Get yourself a flexible drill extension. I don't know how much reach you need but the extensions come in various lengths so get the length you need to reach where the truss is. You may have to first drill a smaller pilot hole to start the screw. You can use the extension to drill the pilot hole then run in a screw.
It's not a major job but can be aggravating.
Camped in every state
Cummins12V98
on the road
Posted: 11/08/21 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
There is wood framing above any pocket door for the track to screw into. PIZZ poor screw type is the issue. Has ZERO to do with roof joists.
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 11/08/21 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
We had the same issue, turned out that they used such small headed screws that the aluminum track pulled off the screw heads. Got a new track and used larger screws, plus put a length of 2x2 under the door in the pocket to help support it's weight when traveling.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
 > Pocket door
