RV.Net Open Roads Forum: Tech Issues: LiFePo battery upgrade question
 > LiFePo battery upgrade question
Page of 6
pianotuna
Regina, SK, Canada
Posted: 11/13/21 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
Teleman,
That is a good decision. Can it be limited to 20 amps if need be? It is a far superior make.
Another reason to have a bypass circuit is for a "poor mans" boost switch. If the chassis batteries are dead, you would be able to get some amps into them from the "house" bank. Don't have it "active" when starting. The Li bms will NOT like it.
If the alternator did fail, then that bypass circuit could be used to keep the engine running a lot longer while getting to a service center. Of course the Redarc ought to be turned off to do this.
Regards, Don
otrfun
On The Road
Posted: 11/14/21 07:19am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
. . . Can it be limited to 20 amps if need be? . . .
This could potentially be an important feature consideration. It'll be interesting to see if the 124a alternator has the headroom to handle the additional ~40a load for the long haul.
Teleman
Clayton, CA, USA
Posted: 11/14/21 08:01am Link  |  Quote  |  Print  |  Notify Moderator
I'll have to look into it. I was originally looking at a 25A unit but that would have been inadequate for 400 watts of solo panels, which I plan to install next spring.
Teleman
Clayton, CA, USA
Posted: 11/14/21 08:03am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Teleman,
What kind of switch do you use? I take it using the house battery boost switch as is isn't recommended? I carry a jump start battery pack too.
pianotuna
Regina, SK, Canada
Posted: 11/14/21 08:06am Link  |  Quote  |  Print  |  Notify Moderator
That would not be a switch. It would be a feature on the dc to DC charger.
Teleman
Clayton, CA, USA
Posted: 11/14/21 08:09am Link  |  Quote  |  Print  |  Notify Moderator
Sorry that wasn't meant for you. Since edited.
pianotuna
Regina, SK, Canada
Posted: 11/14/21 08:22am Link  |  Quote  |  Print  |  Notify Moderator
Teleman wrote:
pianotuna wrote:
Teleman,
Hi Teleman,
I use this type:
https://www.napaonline.com/en/p/NW_786125?impressionRank=3
I like it because I store it with the "key" hanging on a string. It would be nearly impossible to turn it on by accident. Maximum load up to 300 Amp @ 24 Volt DC.
Teleman
Clayton, CA, USA
Posted: 11/14/21 08:26am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Teleman wrote:
pianotuna wrote:
Teleman,
Hi Teleman,
I use this type:
OK thanks.
Teleman
Clayton, CA, USA
Posted: 11/14/21 09:13am Link  |  Quote  |  Print  |  Notify Moderator
Teleman wrote:
pianotuna wrote:
Teleman wrote:
pianotuna wrote:
Teleman,
Hi Teleman,
I use this type:
OK thanks.
Do you place it between the staring battery and the charger or the charger and house battery? How did you mount it?
pianotuna
Regina, SK, Canada
Posted: 11/14/21 10:38am Link  |  Quote  |  Print  |  Notify Moderator
Hi Teleman,
I was able to mount the three I use near the drivers seat in the wall. It makes it quite convenient for switching while I'm trundling down the road.
Page of 6
