RV.Net Open Roads Forum: Class A Motorhomes: air ride height control valve
 > air ride height control valve
brianseay1
Bridgeport, Ala USA
Posted: 11/07/21 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2007 Coachmen Cross Country 389DS. My issue is I have an air ride control valve going bad. I say valve, but it is actually the piece that screws into the actual valve. It has two lines going into it and then it goes into the actual valve assembly. The air ride will not air up on the rear. This piece has two small holes in it coved by a rubber casing around it. I can feel the air being blown out of it. If I pull the rubber casing back and put my fingers over the holes the air ride inflates and stays up like normal. I am trying to figure out what this piece is called. I have found new valves that look just like mine but none of them have this piece with them. Have any of you had these issues before? and if so what did you do to fix it? or does anyone know what this part is called?
* This post was edited 11/07/21 08:58pm by brianseay1 *
Brian & Neena & B.G.
B.G. 2014 Goldendoodle
300 HP Cummins Turbo Charged
03 Sahara Jeep Wrangler & 05 Harley Davidson Ultra Classic
2014 800 RZR4
Roll Tide Roll
eHoefler
ozark mountains
Posted: 11/08/21 04:37am Link  |  Quote  |  Print  |  Notify Moderator
A picture would help, It could be the dump valve that is what you are needing.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
