C Schomer
Pueblo West, Co.
tim, what minimum temp does your trans get. Does GM have a minimum?
2012 Dodge 3500 DRW CCLB 4wd, custom hauler bed.
2008 Sunnybrook Titan 30 RKFS Morryde and Disc brakes
WHOEVER INVENTED WORK DIDN'T HAVE AN RV!
tim1973
Georgia
BenK wrote: Know that 'power mode' has several levels and each has engine/tranny temps as the basis to either turn on power mode, or drop down into a lower power mode
Right down to the various limp modes
All of those decisions are made based on engine/tranny temps
Not sure who you’re talking to. Are you referring to the tow mode feature?
Also my transmission gets up to 180 all the time now that I’ve installed the bypass thermostat. Before I installed it, I’d be lucky to get up to 130, pulling the trailer. No trailer, maybe 105. As far as a minimum, I was always of the train of thought, it needs to get warm enough to work out the moisture.
What’s “power mode?”
2017 Heartland Torque T29
C Schomer
Pueblo West, Co.
180 will sure do it. Craig
hotpepperkid
Kingman AZ
My old 7.3 air to oil would get to 230 going light to light no trailer in Bullhead City AZ in July outside temp 118+. I put an oil cooler from the 6.0's dropped the temp to around 140
2019 Ford F-350 long bed SRW 4X4 6.4 PSD Grand Designs Reflection 295RL 5th wheel
