RV.Net Open Roads Forum: Tech Issues: Toilet broke loose!
 > Toilet broke loose!
BobsYourUncle
Calgary Alberta Canada
Posted: 11/09/21 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
Kober wrote:
Thanks for the replies guys!
The flange is glued to the riser pipe.
Might appear to be glued in...
I took one out once, wrestled, cussed, fought with it before joining RV.Net and posing the question here.
The answer I got was that it is not glued in, but threaded.
Get a drift punch and a hammer and tap it out counter clockwise.
By George that was the ticket. It threaded out of the tank.
Try it, maybe yours is the same. Can't see the threads without sticking your face in the tank, who's gonna do that? Not me..
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
MFL
Midwest
Posted: 11/09/21 02:19pm Link  |  Quote  |  Print  |  Notify Moderator
Good pic OP...worth many words! [emoticon]
Either means of fastening will be great! Getting a good seal, and solid bolt down, will be good to go! (and go n go)
Jerry
StarkNaked
West Seattle, WA
Posted: 11/09/21 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
I had this exact problem.
I used this flange ring: https://www.homedepot.com/p/Oatey-1-4-in........Flange-Replacement-Ring-427782/303864005
Note that it has curved edges, and is not flat.
I kept the broken pieces, and kept them under the flange ring for more support.
I also had to do some minor trimming on the bottom of the toilet since the flange ring takes up slightly more room under toilet.
Gary45
Oshawa, Ontario, Canada
Posted: 11/09/21 04:23pm Link  |  Quote  |  Print  |  Notify Moderator
If you are going to use a wax gasket in your home make sure you get the better one with the plastic funnel built in, a regular wax gasket will leak if your toilet has even a tiny amount of movement, a foam gasket is preferred for any toilet install, they come in a couple of thicknesses. Replaced lots of leaking wax gaskets in homes.
Kober
Arizona
Posted: 11/09/21 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
WOW someone got aggressive on the Throne. [emoticon]
Leave the flange alone. Get two toilet bolts that are a machine thread on one end and a lag screw on the other end. Lay out your holes and Pre drill The size of the solid portion of the lag. Screw lag end into your plywood floor and then set toilet and bolt down.
That sounds too way easy. But eminently doable.
2014 Coachmen Freelander 29qb, towing a trailer with my toys:
2020 Honda Talon SXS, or
2006 Royal Star Tour Deluxe
2008 Road Star 1100
PATRIOT GUARD RIDER, AMERICAN LEGION RIDER
Retired 25 years US ARMY, retired 24 years business owner
Cummins12V98
on the road
Posted: 11/09/21 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
Back in the old days that’s how toilets were held down.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
John Wayne
Long Beach, Ca
Posted: 11/09/21 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
I don' think you're supposed to use wax rings in RV's. RV toilets come with foam rings.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
OkieGene
oklahoma city
Posted: 11/09/21 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
Dude! No more Taco Bell for you!
Vintage465
Prunedale CA.
Posted: 11/10/21 08:07am Link  |  Quote  |  Print  |  Notify Moderator
I had the same thing happen to mine. It is not glued in I can just about promise you. Tanks are generally polyethylene and sewer fitting are ABS, so gluing them in is not an option. Mine had a one piece flange with 3" NPT that screwed into the tank. It was tight as heck largely due to the fact that some type of non hardening caulk was applied to the threads. I had to take a heat gun and heat up the threads from the inside(oh yeah, smelled great!), then I could unscrew it.
https://www.shelllumber.com/united-states-hardware-p-110c-plast-m-toilet-flange.html?feed=Froogle&gclid=Cj0KCQiA-K2MBhC-ARIsAMtLKRvb0khxziBLSkzUn00TPdprJTxcOs8GqIDKvxkLvoivw5RnqpES_WUaArC9EALw_wcB
V-465
2013 GMC 2500HD Duramax Denali. 2015 CreekSide 20fq w/450 watts solar and 465 amp/hour of batteries. Retired and living the dream!
ssthrd
Vancouver Island
Posted: 11/10/21 08:30am Link  |  Quote  |  Print  |  Notify Moderator
Must have had seatbelt on at time of launch.
2014 Keystone Laredo 292RL
2018 GMC 3500HD 6.5' box SRW Denali Duramax Andersen
DeeBee, JayBee, and Jed the Black Lab
