RV.Net Open Roads Forum: MAJOR short on a 2006 newmar essex
 > MAJOR short on a 2006 newmar essex
rabnud
california
Posted: 11/09/21 04:18pm Link  |  Quote  |  Print  |  Notify Moderator
regarding a 2006 essex any one know what the #293 module is for;; its in the main control system for heat /ac/ gen start/ inverter/ etc etc says module #293 failed
also have a major electrical issue where at the same time the water pump stays on the generator starts all by itself ,the lights flash and the and the main control panel says missing a module #293)
also if u turn the ignition key on the dash lights for the engine controls etc illuminate even though the chassis battery is turned off!! (wont start or turn over though) If u turn the headlight switch on and off everything goes off /back to normal also the brake control flashes and goes off when the headlite switch is pulled on/off as the other stuff
any and all ideas and questions welcome
hohenwald48
Nashville, TN
Posted: 11/09/21 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
I'd be looking for a bad ground connection somewhere with all those odd symptoms.
When seconds count, the police are only minutes away.
2019 Newmar Canyon Star 3627
2017 Jeep Wrangler JKU
enblethen
Moses Lake, WA
Posted: 11/09/21 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
Some of your listed items are on the coach battery system.
Have you cycled the chassis battetry disconnect?
Have you had any battery(ies) worked on?
Check around battery(ies) for a dropped cable.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
MountainAir05
New Mexico
Posted: 11/09/21 05:15pm Link  |  Quote  |  Print  |  Notify Moderator
Think you have a control failure. A short and you would not have anything electrical working. Try these links. There were several recall on this. Its a old system and no repair that I have found, just remove and go without or put in another system. Its was a monitoring system that did not last long. Too long ago to remember all the issues. Seems like you could turn it all off and take the power off it. The first link might have that info.
Eplex
#2
rabnud
california
Posted: 11/09/21 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
iam kinda leaning that way just dont understand the dash powering up when key turned on when the battery is disconnected and turning the headlite switch on and off kills the power to it that was there
rabnud
california
Posted: 11/09/21 10:09pm Link  |  Quote  |  Print  |  Notify Moderator
1) several times
2) no
3) did
this all started after the guy pressure washed the battrys but never removed any cables etc I double checked the wires etc to the battrys
and nothing seems out of order
rabnud
california
Posted: 11/09/21 10:13pm Link  |  Quote  |  Print  |  Notify Moderator
Eplex
#2
thanks for the information;;Iam leaning more towards a grounding problem once i find out what the #293 module is It may help me some also
also the on board security system started going on all by itself
when this first happened the unit was running and it locked the door while they were outside the coach while it was running ;;luckly it also resets itself
MountainAir05
New Mexico
Posted: 11/10/21 07:33am Link  |  Quote  |  Print  |  Notify Moderator
Eplex
#2
Sounds like you got some water inside a sensor or relays. If the relays are not seal which sound like they are not, then you can take apart and dried out. Hopefully it will dry out fast. Leave the battery disconnect for 30 + minutes if you do a reset again.
* This post was edited 11/10/21 09:59am by MountainAir05 *
enblethen
Moses Lake, WA
Posted: 11/10/21 07:41am Link  |  Quote  |  Print  |  Notify Moderator
From another RV forum:
"Final update: FIXED IT!!!!!!!!! Received The actual eplex wiring diagram from Newmar. The E-plex fuses are located in the back of the shore power cord compartment.* There are two inline fuses and a 24v step up converter installed. Newmar used the step up converter only the first year and realized wasn’t required. I bypassed and removed the converter. Two fuses were good, but there was a 12v panel the red wire connected to with a 5amp fuse.. it was blown. Power returned to the system."
Might look for fuses on your rig.
rabnud
california
Posted: 11/10/21 08:19am Link  |  Quote  |  Print  |  Notify Moderator
will take a look although My eplex works and has power to it just sometimes it goes into the missing modules display and then you cant control anything ;; also have to find out where the phantom power to the dash comes from when turning on key with chassis batterys disconnected and why turning on the head lites shuts it off
and why the water pump sticks on and starts the generator this is a perplexing mess so far
