RV.Net Open Roads Forum: General RVing Issues: Winter battery maintenance
 > Winter battery maintenance
Veebyes
Posted: 11/11/21 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Bring them home. Mostly so that somebody does not want them more than you. There is no need for a maintainer. Every month, maybe two, give them a charge enough to bring up to full charge. Wet cells in good condition will only lose about 10% charge per month in storage.
2007 Alpenlite 34RLR
Fisherman
Angus, Ontario, Canada
Posted: 11/12/21 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
I find it amazing the amount of info people put out there when it comes to batteries. Idle batteries, ie, not being on a maintainer do sulfate and once that happens the batteries loose capacity. Your money, quit trying to hose others that like to keep their equipment in good shape.
olfarmer
Iowa
Posted: 11/18/21 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
I agree with Fisherman, my batteries are 10 years old and still going. I credit the battery maintainers with the long life. I have antique cars and also keep maintainers on them and have very good luck with long life batteries in them too!
Ed & Ruby & the 2 cats
2001 Winnebago Brave 30W
7.4 gas Work Horse Chassis
99 Jeep Grand Cherokee
Boon Docker
Posted: 11/18/21 11:27pm Link  |  Quote  |  Print  |  Notify Moderator
My batteries have sat disconnected outside for 6 months each year through the winter for 9 years now with no maintainer and have not lost capacity.
I must have some pretty special batteries that can do that. [emoticon]
JaxDad
Greater Toronto Area
Posted: 11/19/21 06:56am Link  |  Quote  |  Print  |  Notify Moderator
Our tractors run 4D and 8D batteries, big honkin’ FLA batteries.
They typically get parked about this time of year until around Easter.
Most are never touched or have any charger on them that whole time. Some of those batteries are well over 10 years old.
The 2 tractors we do use in the wintertime have a cheap 6 or 10 amp charger on them plugged into a cheap lamp timer that powers the chargers for an hour a day, around 3 or 4am usually.
No need to make stuff complicated.
CavemanCharlie
Storden,MN
Posted: 11/19/21 11:33am Link  |  Quote  |  Print  |  Notify Moderator
On older tractors this was what we do. On our newer tractors the parasitic draw will drain the battery down after a month or so. One of the newer tractors has a built in switch so you can shut the battery off. On the other one we have to put a battery maintainer on it.
