RV.Net Open Roads Forum: General RVing Issues: Black Water Valve Will Not Close
 > Black Water Valve Will Not Close
pmlevine
Massachusetts
Posted: 11/10/21 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
It was our last TT trip of the season - all was well, I had opened and closed the black water valve at our campsite a couple of times with no issues. The last day after emptying the black water tank I went to close the valve and it wouldn’t budge. When I applied some force the valve rod bent. I straightened it as best I could and tried to close the valve but the metal rod will not move. Now the rod interface at the frame is loose - the threaded hollow screw at the frame that the rod goes through, the and the nut that secures it to the frame are loose, and I don’t seem to be able to tighten it up. Any ideas guys - help ..:
Cummins12V98
on the road
Posted: 11/10/21 11:18pm Link  |  Quote  |  Print  |  Notify Moderator
Remove four bolts and replace valve.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
larry cad
ohio
Posted: 11/11/21 03:40am Link  |  Quote  |  Print  |  Notify Moderator
X2
Our Travel Blog
Dave in TN
Middle Tennessee
Posted: 11/11/21 06:00am Link  |  Quote  |  Print  |  Notify Moderator
X3.
The good news is the tank is empty and you have all winter to fix it.
pmlevine
Massachusetts
Posted: 11/11/21 07:58am Link  |  Quote  |  Print  |  Notify Moderator
Okay guys thanks. We used our TT as a lifeboat when we lost power recently. If we need to find warm shelter this winter, I’ll just put double garbage bags to line the TT toilet, and we’ll hunker down. Black valve R&R will have to wait til later.
Gjac
Milford, CT
Posted: 11/11/21 08:27am Link  |  Quote  |  Print  |  Notify Moderator
I drilled a small hole in the top of the valve and put a self tapping grease fitting in there. When every it gets hard to open I pump some grease in there and it operates smoothly again. For some reason it is always the black valve that sticks never the gray valve. You can also just drill a hole and spray lubricant in the hole and put a screw in the hole after the valve is freed up.
navigator2346
Wa and points South
Posted: 11/11/21 10:12am Link  |  Quote  |  Print  |  Notify Moderator
Better stuck open than closed. Replace the valve and be done with it. Consider yourself lucky and go buy a lottery ticket.
wnjj
Cornelius, Oregon
Posted: 11/11/21 11:20am Link  |  Quote  |  Print  |  Notify Moderator
Put one of these on and get through the winter: https://www.amazon.com/Valterra-T58-Twis........t+on+rv+dump+valve&qid=1636654797&sr=8-3
ssthrd
Vancouver Island
Posted: 11/11/21 11:31am Link  |  Quote  |  Print  |  Notify Moderator
Suggest putting a good flow of water in the tank with a garden hose or a bucket and work the valve at the same time. Could be something stuck in the valve that might free itself with a little help..
2014 Keystone Laredo 292RL
2018 GMC 3500HD 6.5' box SRW Denali Duramax Andersen
DeeBee, JayBee, and Jed the Black Lab
rockylarson
Jersey Shore
Posted: 11/11/21 11:55am Link  |  Quote  |  Print  |  Notify Moderator
X2
Jan and Rocky
Volunteers for USFWS. 29 refuges with 9300 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
