RV.Net Open Roads Forum: Tech Issues: Battery tray for LifePo 200AH Battery?
 > Battery tray for LifePo 200AH Battery?
Teleman
Clayton, CA, USA
Posted: 11/11/21 06:49am Link  |  Quote  |  Print  |  Notify Moderator
I just bought a LifePo battery to replace my two lead acid deep cycle batteries and I'm having trouble finding a hold down tray for it. It measures 20.5x9.4x8.5 inchs. The bottom is 19"x9". Any ideas?
* This post was last edited 11/11/21 01:26pm by Teleman *   View edit history
StirCrazy
Kamloops, BC, Canada
Posted: 11/11/21 10:44am Link  |  Quote  |  Print  |  Notify Moderator
Teleman wrote:
I just bought a LifePo battery to replace my two lead acid deep cycle batteries and I'm having trouble finding a hold down tray for it. It measures 20.5x9.4x8.5 inchs. Any ideas?
got any pictures of where the batteries were?
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
pianotuna
Regina, SK, Canada
Posted: 11/11/21 11:17am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
Roll your own. Make sure it is well ventilated li hate heat.
Regards, Don
Boon Docker
Posted: 11/11/21 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
This box should work for you.
Teleman
Clayton, CA, USA
Posted: 11/11/21 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
Steve
No but they are behind the grill and separated from the engine by a firewall as it's a Class A motorhome.
Teleman
Clayton, CA, USA
Posted: 11/11/21 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
I prefer a tray if that's ok. The battery will get wet but that shouldn't be a problem correct?
Boon Docker
Posted: 11/11/21 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
A wet battery is no problem.
I looked, but could not find a tray that size or even close to that size.
Teleman
Clayton, CA, USA
Posted: 11/11/21 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
Me neither. I guess most RVs have slide out trays for batteries large enough to accomodate these big guys. I was surprised my house batteries were up front under the hood when I bought it.
Boon Docker
Posted: 11/11/21 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, there are a lot of slide out trays about that size.
Maybe find a heavy duty plastic tote, cut the top part off and use the bottom for a tray. Or get a welder to make you one out of diamond plate or aluminum.
Veebyes
Posted: 11/11/21 06:58pm Link  |  Quote  |  Print  |  Notify Moderator
I currently have a 4D case sized AGM. It sits on the stock tray which held 2 12V grp 24 batterys. I have at least another 5 years estimated for the AGM 4D but I think a 200ah LifePo will be in my future. It will fit the stock tray on the 5er.
2007 Alpenlite 34RLR
