RV.Net Open Roads Forum: Tow Vehicles: Bought a second truck.
Search only in Tow Vehicles
 > Bought a second truck.
Page of 16
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 11/22/21 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
Nice! Always liked that body style.
Throw a four barrel on it and hang on!!!
And check on advancing the cam.
2021 F150 2.7 Ecoboost - Summer Home 2017 Bighorn 3575el. Can Am Spyder RT-L Chrome, Kawasaki KRX1000. Retired and enjoying it!
FishOnOne
The Great State of Texas
Posted: 11/22/21 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
FishOnOne wrote:
Nice truck... The one thing I couldn't understand is why Ford predominantly used 2 barrel carburetors in their trucks which made them real slugs.
My 69 F100 Ranger 360 2 barrel was a DOG. Changed a couple things wa-la 390 plus 4 barrel was bad azz and got better fuel economy. Had the C6 BUILT and was amazing.
Agreed... Running in 2 barrel mode on a 4 barrel carb made better fuel economy than a 2 barrel carb.
I remember my parents and their friends pulled their campers from Texas to Ontario Canada back in 1982 and their 1981 Chevy 305ci truck, a friends 1980 GMC 350 both with 4 barrel carbs always made better fuel economy compared to the two Ford F250's with a 400 and 351 2 barrel setup.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"200k Mile Club"
'16 Sprinter 319MKS "Wide Body"
specta
utah
Posted: 11/30/21 08:40pm Link  |  Quote  |  Print  |  Notify Moderator
I got my new dash pad and set cover installed.
And a new windshield washer fluid reservoir, pump and new wiper blades installed.
Today I changed the oil and filter, first time its been done in over 20 years.
I added a cleaner and ran it for about 10 minutes prior to draining the oil.
The oil looked like black gasoline.
I also got my new glove box liner from Dennis Carpenter installed. The old one crumbled when I took it out to install the new dash pad.
Now I can keep the original owners manual in there. [emoticon]
And a new battery tray.
New brake and clutch pedal pads.
I also got the old ugly home mead trailer hitch off too.
I have a new one from etrailer that I will get installed soon.
I got the old heat passages drilled and cleaned out for the heat for the choke.
I still need to make a new inlet tube but now the choke works like its supposed to and opens when the engine gets warm.
I even got a new passenger side headlight replaced.
Still TONS to do. It needs new transfer case mounts, the front yoke on the front driveline replaced, both u-joints on the rear driveline and still more.
Its a fun project and its pretty fun to drive too.
Kenny
2011 Chevy 2500 HD 6.0L 4wd
specta
utah
Posted: 11/30/21 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
When I took off the brush guard one side of the grill was busted out.
I replaced too. The passenger side was busted up.
Once I have everything fixed and its road worthy I'll decide if I'm going to do anything to the engine.
If I decide to improve its performance I'll go with a 428 CJ cam and a 4-bbl carb.
JRscooby
Indepmo
Posted: 12/01/21 04:48am Link  |  Quote  |  Print  |  Notify Moderator
In my mind the pedal rubbers are upside down.
Geo*Boy
Unknown
Posted: 12/01/21 07:16am Link  |  Quote  |  Print  |  Notify Moderator
OMG, your replacing ALL that stuff, you should have saved yourself time and money and bought a new truck.[emoticon]
specta
utah
Posted: 12/01/21 08:02am Link  |  Quote  |  Print  |  Notify Moderator
When I first put them on they were the other way around.
Then I looked at the picture before I replaced them and turned them around.
They do look upside down.
I guess its time to go to a Ford truck forum and find out which way is correct.
* This post was edited 12/01/21 08:09am by specta *
specta
utah
Posted: 12/01/21 08:12am Link  |  Quote  |  Print  |  Notify Moderator
True, but I also got a new career. [emoticon]
specta
utah
Posted: 12/01/21 11:44am Link  |  Quote  |  Print  |  Notify Moderator
Fixed. Thank you. [emoticon]
Krusty
Calgary, Alberta,Canada
Posted: 12/01/21 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
Looking great
Krusty
92 F-250 4x4 460 5spd 4.10LS Prodigy
97 Rustler RT190
EU2000i
Garmin
Page of 16
