specta
utah
cummins2014 wrote:
It will definitely raise your heart rate , especially when you are on the brakes , and you start sliding sideways , so you let off , and then repeat , I came off a couple a bit faster then wanted . Or climbing and spin out , I got to when I’d lose momentum I’d let off throw it in reverse, and pop the clutch to catch me going backwards , that also raised the heart rate . Or spin out kill the engine , both feet on the brake , and sliding backwards, that was exciting . ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
Been there done that in my other truck. Never had an issue with the t-case. Sometimes you just end up in one of those situations and you do the best you can.
Kenny
2011 Chevy 2500 HD 6.0L 4wd
1976 Ford F-250 6.4L 4wd
specta
utah
![[image]](https://i.postimg.cc/L56R7dq5/IMG-8095.jpg)
I just took it across the scales this afternoon.
Myself, a full tank of gas and two spare tires in the bed weigh roughly 400 pounds making the truck about 5000 lbs dry.
The truck also has an aftermarket auxiliary gas tank but it is empty so it might not even weigh 5000 lbs from the factory.
So with a 7700 lb GVW rating it is capable of carrying around 2300 lbs.
Its kind of a light weight for a 3/4 ton truck.
rjstractor
Maple Valley, WA
Its kind of a light weight for a 3/4 ton truck. ![wink [emoticon]](http://www.rv.net/sharedcontent/cfb/images/wink.gif)
Those older trucks are definitely light compared to today. I used to have a '72 F100 2WD with a GVWR of just 5000 lbs, not much more than an empty, stripped down F150 today. Empty and from the factory it had to weigh under 4000.
Right? All the fancy chit, crew cabs, etc really add up.
What gets me is the old trucks are so much lighter, yet the sheet metal is so much thicker.
Cripes, the hood on our 2016 Ram looks like it's made of cellophane, when driving down the highway. I'd gladly add a few hundred lbs in sheetmetal and real bumpers, compared to today's trucks.
But credit where credit is due, a good portion of weight in the newer trucks comes from much stiffer chassis, bigger better axles, bigger brakes, etc, compared to the old iron.
2017 Heartland Torque T29
Cummins12V98
on the road
AMZ/OIL makes a great oil for older engines.
Z-ROD® 10W-40 Synthetic Motor Oil
Specially engineered for classic cars. Contains high levels of ZDDP, top-tier additives and rust inhibitors to protect your passion, deliver maximum performance and keep your classic engine free of rust and corrosion in storage.
See the Product Data Bulletin for full details.
PROTECTS FLAT-TAPPET CAMS
Formulated with high levels of ZDDP to protect flat-tappet cams, lifters, rockers and other areas susceptible to wear.
High-zinc, high-phosphorus formulation provides the extra wear protection critical splash-lubricated components require.
Fights wear to help prevent compression loss for maximum horsepower.
HELPS PREVENT RUST & CORROSION
Formulated with a unique blend of rust and corrosion inhibitors to ensure maximum protection during long-term storage.
Prevented rust and corrosion in industry standard testing (ASTM D1748-10) for excellent engine protection.
Z-ROD Delivers Superior Rust Protection
In industry standard testing, AMSOIL Z-ROD completely prevented rust formation while a leading competitor did not.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
specta
utah
Amsoil makes great products period.
Z-rod is a bit pricey for me, nearly 3 times what I paid for the Valvoline.
The engine is old and tired and when everything else has been fixed I'll be looking for another 390 to rebuilt. One that wont require zinc.
specta
utah
They were a lot lighter than today's trucks for sure. But then there wasn't much to them.
My 2011 Chevy 2500HD regular cab 6.0 gasser 4-wd weighs 6580 lbs empty.
specta
utah
I've just driven my truck around the canyon here where I live.
When I took it to the scale to weigh I took the old highway and took the freeway home.
I kept it at 65 mph on the freeway. I'm sure its the first time in a LONG time its seen a freeway.
In 70 miles it spit out 2-3 qts of oil out through the front intake manifold gasket.
Gaskets and valve stem seals on their way.
My place is starting to look like a parts store.
I can't wait until its not a Fix Or Repair Daily truck.
blt2ski
Kirkland, Wa
My 1981 and 2000 reg cab C2500's were around 4800 dry, with 8600 factory gvw the had just shy of 2 tons of payload.
My 1500 dual cab 4x I'd 5300-5400 empty per GM.
I'm generally 5700-5800 including my phat arse coming out of the dump. I have a factory gvw of 7200.
A few lighter trucks around.
Marty
2014 Chevy 1500 Dual cab 4x4
specta
utah
This truck and my other truck are the only two I've had on the scales.
And my newer one is a lot heavier.
