RV.Net Open Roads Forum: Carrying a 500 lb motorcycle on the back of a Solitude 5er
 > Carrying a 500 lb motorcycle on the back of a Solitude 5er
klr650goldwing
minnesota
Posted: 11/11/21 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
Has anyone carried a 500 lb motorcycle on the back of a Solitude 5th wheel? Did you reinforce the receiver hitch on the trailer? Any negative pin weight consequences? Please tell me about the pros and cons of doing such a thing.
2014 Grand Design Solitude 369RL
2017 F350 6.7 DRW CC LB 4X4
2012 Mercedes E550
2010 Honda Civic
2009 Saab 93 Aero Convertible
2004 Honda Goldwing GL1800
2004 Kawasaki KLR650
1966 Honda 305 Dream
patperry2766
Saginaw Texas
Posted: 11/11/21 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
I see the potential for this not ending well on so many levels.
#1 seriously doubt the hitch is rated to that weight, in addition to the probably 100 lbs+ of the motorcycle carrier
#2 500 lbs bouncing up and down quickly will stress out the frame
#3 you should be able to pick up a small used trailer off craigslist for $500-1000. That way you could carry more than one toy, gas cans, etc and it would be safer all around.
Not saying it couldn't be done, but there are better
options
Courage is the feeling you have right before you fully understand the situation
TXiceman
Full Time RVer
Posted: 11/11/21 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
I doubt if you asked, GD or Lippert they would approve such loads on the back of their frame. Next is 500# plus the carrier frame on the back will lighten the pin and provide a poor ride and handling.
Ken
Amateur Radio Operator.
Cummins12V98
on the road
Posted: 11/11/21 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
Yes it can be done but it would need to be reinforced for sure.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Veebyes
Posted: 11/11/21 06:28pm Link  |  Quote  |  Print  |  Notify Moderator
Way back in 2005, when we were researching, we considered getting a bike to carry on the back of the 5er. The bike we were thinking of is the Yamaha TW200, a cross trail & street bike weighing about 260lbs.
We questioned the Carriage builders at an RV show. The answer was, even with reinforcement of the frame, estimated to weigh at least 100lbs, the net weight of bike & carrier well over 300lbs would be too much.
2007 Alpenlite 34RLR
wildtoad
Blythewood, SC
Posted: 11/11/21 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
Best bet is to swap the fifth wheel for a toy hauler, or a double tow (where allowed) with a utility trailer.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
valhalla360
No paticular place.
Posted: 11/12/21 01:36am Link  |  Quote  |  Print  |  Notify Moderator
Look into swivel wheel trailers.
They are a gray area in terms of double towing as the can't jack knife. The advantage is they cut the weight on the back of the trailer by roughly half.
The big thing to check is what is your current pin weight. You should be north of 20% of the trailer on the trucks pin and putting 600-700lb off the back will take several hundred pounds off the pin.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
eHoefler
ozark mountains
Posted: 11/12/21 06:18am Link  |  Quote  |  Print  |  Notify Moderator
Keep in mind, for every pound you put on the bumper, you will remove in tongue weight proportionately, with out specs on your rig, cannot calculate. The weight on the rear will be doubled at the axles, do you have enough capacity left to carry an extra 1000-1200 pounds
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
Lantley
Ellicott City, Maryland
Posted: 11/12/21 08:04am Link  |  Quote  |  Print  |  Notify Moderator
Does your 500# figure include the weight of the rack or contraption you plan to use to carry/support the motorcycle?
Once upon a time I carried a 170# genset on a rear rack and it definetly impacted my tongue weight.
Including the weight of the rack you will be close or in excess of 700#.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
laknox
Arizona
Posted: 11/12/21 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Yes, it can, and has been, done. You'd want to reinforce the frame from the rear a minimum of 4-5' to the front, if not all the way to in front of the rear spring hangers. You'd also want to add several cross braces. Bouncing is likely to be a problem. Look at what people with rear kitchens can face, and that's =inside= the rig, not hanging 3-4' off the back. Handling can be affected but, IMO, not as much as you might think. If you =do= have handling problems again, IMO, you're already marginal on pin weight to begin with.
Alternatives:
1) Easiest, IF IT'S LEGAL, would be to tow a small trailer. You'd likely also want to add a rear view camera, NOT a backup cam, so you can keep an eye on the trailer.
2) Add a swivel wheel tote. You'd still have to do some beefing up of the frame, especially if you use one that uses dual receivers to mount. Be aware that even one of these, that's mounted to the frame, is considered by some states to be a "trailer" and, if double-towing isn't legal there, you can get ticketed for it. I do know of one instance where someone added a swivel wheel to his FW but took it off after only a couple trips, as it =did= affect handling. Now, this was with a Gold Wing-sized bike, so likely added a =lot= more than 500 lbs to the back of the FW.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 63 Year Member
