RV.Net Open Roads Forum: Tech Issues: 5500 Onan starts then dies, help please
 > 5500 Onan starts then dies, help please
RV-1/2n-FUN
FL.
Posted: 11/11/21 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
2008 Onan 5500 that I neglected and did not run every month with load since May. Using start switch on the generator, first priming then start the gen. It starts and runs ONLY as long as I hold almost completely closed the butterfly under air filter. If I take pressure off the B-fly opens wide and sounds like gulping air then shuts down with code flashing 36. Reset code, prime and start up and again runs only by holding closed the butterfly. Sprayed plenty of Seafoam in to no avail.
Any ideas of problem???
TIA
dougrainer
Carrolton, Texas
Posted: 11/11/21 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
The seafoam did not work. You need to remove the carb fuel bowl and unscrew the needle jet assbly and clean out the 16 holes with regular carb spray. The carb is varnished/gummed up. Doug
RV-1/2n-FUN
FL.
Posted: 11/12/21 01:22am Link  |  Quote  |  Print  |  Notify Moderator
Thanks [emoticon]
Will put your suggestion on today's "must do" list.
A1B00902
Vancouver B.C CANADA
Posted: 11/12/21 10:56am Link  |  Quote  |  Print  |  Notify Moderator
check the oil level, Onan will not run if low on oil
dougrainer
Carrolton, Texas
Posted: 11/12/21 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
True, but holding the choke butterfly would not override the oil pressure LOPKO. Doug
Dirtclods
Newport Beach
Posted: 11/12/21 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
Seafoam is a fuel treatment it doesn't work well after a problem exist. You gotta have in the tank and if your running lower octane fuels you'll get more **** built up in the carb.
Fisherman
Angus, Ontario, Canada
Posted: 11/12/21 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
Octane has absolutely no effect on the amount of crud building up in a fuel system.
Posted: 11/12/21 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
You sprayed seafoam into the throat of the Carb.
But from your description I'd say it needs carb cleaned.
it is SLIGHTLY possible that adding seafoam to the tank might help
But I think Disassembly and cleaning is in order.
NOTE: This is not the only possible issue.
RV-1/2n-FUN
FL.
Posted: 11/12/21 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
Broke down the carb today and the inside looked as clean as the day it was assembled. Didn't have any cleaner so put Seafoam through everything then reassembled and WHAM-BAM it ran but only for 5 minutes.
Same as before r.e.-shutting down, so held butterfly and it ran great.
THANKS for the replies.
* This post was edited 11/24/21 05:26am by RV-1/2n-FUN *
RV-1/2n-FUN
FL.
Posted: 11/24/21 05:30am Link  |  Quote  |  Print  |  Notify Moderator
Generator starts better than before then only runs for 4 minutes and dies. Checked pump with hose disconnected and pressure seems good so totally flustered and figure it's time for $$$$ and a pro.
