RV.Net Open Roads Forum: Fifth-Wheels: Sailun Tires
 > Sailun Tires
buc1980
houston tx
Posted: 11/14/21 07:23am Link  |  Quote  |  Print  |  Notify Moderator
Lantley wrote:
Sailun did not develop its stellar reputation overnight.
Much in the way a RV trailer puts added stress on a tow vehicle vs. most other family use trailers. RV tires should be held to a higher standard than a typical trailer tire.
RV tires carry a very non aeroadynamic load. They are heavily stressed when parked in tight spots. Typically they carry a heavier load than most non professional trailers their size
They are used 100's of miles away from home, often in remote areas.
Using a no name off brand tire for a utility trailer or a locally used boat trailer does not require the same rigor and reliabilty required by an RV trailer.
With that in mind I prefer the weight, additional capacity margin and stellar reputation of Sailun vs. the other off brand tires.
Sure you could gamble with some other off brand RV tire, but why when there is a proven and tested tire available? Sailun its reputation speaks for itself.
I agree Sailun WAS a very good trailer tire but with the relocation of the manufactures to Vietnam the reputation was going downhill fast.Goodyear 614 was a very bad tire when they start,I got 3 blow on them now they OK but the price is ridiculous high.
2017 Ford F350 DRW,2005 Kountry Star 35ft,16750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.Full body paint 2022.
Bayley
Meridian
Posted: 01/20/22 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
Well it appears that the quality issue was on tires manufactured in mid 2020 according to the recall. The tires I received were manufactured a year later so hopefully Sailun corrected the problem and I'm good to go.....the tires are certainly heavy duty!! We'll see how they perform.
Semper Fi
Tony, Darlene & the boss Bentley!
2013 Ram CTD, Ride-Rite Air Bags, B&W Turnover Ball and Andersen "Ultimate 5th Wheel Connection".
2014 Arctic Fox 29-5K 5th wheel with Reese Airborne Pin Box.
 > Sailun Tires
