RV.Net Open Roads Forum: Class A Motorhomes: Advice please
wjschill
Posted: 11/12/21 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
Our (new to us) motorhome has a small section of outside trim that has separated from the fiberglass wall. It's about a 20 inch gap (about 3/8") that I can pull open, but not able to get inside for a good cleaning.
What is the best adhesive to use? This is my only one shot, so I want the best I can get.
Thanks....
Skip
KillingTime
rgatijnet1
Posted: 11/12/21 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
I know that I have had great luck using the Gorilla products. Perhaps you may find one of their adhesives that will work the best. The most important thing is that you use something to get inside the gap and clean the surfaces with alcohol first to insure a good bond. Determine what the composition is of the two surfaces and then do a search for the best adhesive.
Posted: 11/12/21 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
Gorilla or GOOP Goop is not as strong but it is easier to use.
lryrob9301
Mid-Atlantic
Posted: 11/12/21 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
3M Trim Cement available at any auto parts store.
2013 Tiffin Phaeton 40QBH
2016 Chevrolet Equinox LTZ AWD V6
chuckftboy
Fleming Island, Florida
Posted: 11/12/21 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
Body moldings on cars and trucks is installed with 3M VHB tape. If it holds door amd trim molding on a pickup it should hold on an RV
2019 Horizon 42Q Maxum Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
wjschill
Posted: 11/13/21 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
OP here.
I went with the Gorilla two part epoxy. I mixed it in a large syringe from Walmart and applied under the trim. I cleaned under the trim with rubbing alcohol before applying.
I positioned a board with a little force on top of the trim. Looks like this will work just fine.
Will remove board tomorrow.
Note: If you want to use this method, be ready to apply the epoxy ASAP, as it sets up in the syringe in about five minutes.
Thanks for the input.
Skip
