RV.Net Open Roads Forum: Class C - with ability to tow
 > Class C - with ability to tow
upmm019
Posted: 11/14/21 08:16am Link  |  Quote  |  Print  |  Notify Moderator
Exploring doing a year-long RV adventure and was hoping to get some advice on a Class C.
It would be myself/wife/two medium sized dogs and our Jeep Grand Cherokee.
So I need something that will not break the bank but will give us room and ability to tow. I have no RV experience - once had a travel trailer but that was the extent. I have never driven a large RV.
Looking to explore the southwest during winter and northern parts off-winter.
I still work (telecommunte) so most likely staying at places weeks at a time. So also curious to know if there is a website/forum, etc that points out some of the great places to stay with good wifi/amenities etc
Thx -
PartyOf Five
Wheaton, IL
Posted: 11/14/21 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Best to rent something and then tell us more about your preferences and needs.
PartyOf5 appreciating our Creator thru the creation. 5 yrs, 50k
May you find Peace in all you endeavor.
wanderingaimlessly
Buggs Island lake
Posted: 11/14/21 08:44am Link  |  Quote  |  Print  |  Notify Moderator
For starters, your Grand Cherokee is likely somewhere around 4500 lbs. (check your stickers/manual)
Most "C"s are on Ford chassis with pre 2020 being a 6.8 V-10, and the newer having the 7.3 V-8.
2016 and older will have the 5 speed tranny, newer has the 6 speed.
General reviews are that the 6 speed is a major upgrade.
Most will have a 5000 lb tow cap, with a few offering 7500.
Either drivetrain is capable of what you are looking at.
As to the C itself, floor plan is your first major concern, determine what types of spaces you need. Separate rear bedroom etc, If you plan on dry camping (Boondocking) tank sizes become important, anything over a 35 gallon black will last a couple weeks generally with anything under 50 gallons on the grey likely limiting you to a week or even less. Fresh will match your grey production but its pretty easy to carry extra fresh in a couple of 5 gallon totes/jugs.
As to how where to travel, I'd suggest starting on Youtube, and then from the working on the road side check out www.Escapees.com they have a lot of discussions on their site covering much of that as well as membership gaining you some discounts on campsites.
As to wifi, if good speed is needed for work, explore cellular data plans and their abilities, campground wifi is hit or miss, mostly miss. They will advertise it, but for anything beyond checking e mail and basic web surfing it often is inadequate.
Hopefully this gives you some ideas of where to start.
carringb
Corvallis, OR
Posted: 11/14/21 08:57am Link  |  Quote  |  Print  |  Notify Moderator
Any E450 motorhome will pull you jeep.
There is a huge variation in Cargo Carrying Capacity so it might not hurt to start figuring what you might need to pack for long trips, and this might limit the max size unit that will work for you, since larger = less CCC.
2014 ORV really big trailer
2015 Ford Focus ST
Anza-Borrego Desert SP area
Posted: 11/14/21 09:06am Link  |  Quote  |  Print  |  Notify Moderator
I agree with the comment recommending renting a couple of Cs before you buy to decide on a floor plan and with being very careful about CCC and the C maximum tow weight. Do it once carefully.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
bobndot
Posted: 11/14/21 09:34am Link  |  Quote  |  Print  |  Notify Moderator
Check your real Jeep weight for towing . If you plan to haul gear in it bc you plan long term stays , be sure to take cargo into consideration.
**if you plan to 'flat-tow' the GC, make sure you can. Not all are flat towable, depends on the drive system.
I agree 100% with PartyOfFive, RENT first !
See how much room, floorspace, you need with the 2 dogs always in the way.
* Beware that many 'C's use a base entry level chassis without power seats or power mirrors. I personally like the Jayco seats with leatherette and power swivel bases.
Check the comfort level of seats in the cab as well as in the rv. I would want recliners or at least a sofa as well as a dinette .
If you are used to towing a TT, expect a MH to be more noisy when driving it. You don't hear things rattling around when towing a TT.
jdc1
Rescue, Ca
Posted: 11/14/21 10:22am Link  |  Quote  |  Print  |  Notify Moderator
Why limit yourself to a Class C?
bukhrn
Lanexa, Va
Posted: 11/14/21 10:37am Link  |  Quote  |  Print  |  Notify Moderator
X-2, Class A will likely have a lot more room.
2007 Forester 2941DS
2014 Ford Focus
theoldwizard1
SE MI
Posted: 11/14/21 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
Class C would be marginal for towing your car. Super C or Class A.
Forget the bank account !
rjstractor
Maple Valley, WA
Posted: 11/14/21 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
Please define "marginal". The E450 can tow a 5000 lb Jeep with a significant margin in GCWR. GVWR is not a factor when flat towing since there is virtually no tongue weight.
