RV.Net Open Roads Forum: General RVing Issues: House Battery
 > House Battery
joelc
Cedar Point, NC
Posted: 11/14/21 11:18am Link  |  Quote  |  Print  |  Notify Moderator
I am looking for a battery for my fifth wheel. I guess it is called a "house battery". For the purpose of running my 12V system in the event power fails or for not being connected to a post. My primary question is what battery group do you have, and my other question is what brand of battery do you have. I will have a single 12V deep cycle battery. One store recommended a group 24 and another tore recommended a group 31 battery.
PartyOf Five
Wheaton, IL
Posted: 11/14/21 11:31am Link  |  Quote  |  Print  |  Notify Moderator
Your existing battery should list the group number, or you might even see the brand and model. We've had good luck buying at batteries plus, and Interstate also stand behind their batteries.
PartyOf5 appreciating our Creator thru the creation. 5 yrs, 50k
May you find Peace in all you endeavor.
MFL
Midwest
Posted: 11/14/21 11:47am Link  |  Quote  |  Print  |  Notify Moderator
A bigger battery group 31, or 27, likely better choice, than 24, depending on length of time not connected. If just a short term power disruption, a 24 will serve you without issue. I like the Interstate brand, but most brands will do the job, if fresh to start with, and properly maintained.
Jerry
Seneca 35GS
whittier
Posted: 11/14/21 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
As MBL stated he prefers Group 31 or 27, I agree. I personally like Lifeline AGM batteries. No maint. long lasting, no terminal corrosion and a mid price point between lithium-ion, and flooded cell varieties.
Posted: 11/14/21 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
Ok my standard battery post (I need to save it to documents/boiler plate
Batteries come in several differnet types
Most trailers are set up to us a SINGLE 12 volt battery Often a Group 27 or 29
These are about 100 amp hours (Less or more respective) and are usually MARINE/rv or MARINE/deep cycle meaning you can use about 25 of those amp hours (same less/more) Not your best choice. Group 31 is about 130 AH and again you can use about 1/4
Using more than that "Ages" the battery rapidly.
If you can fit them a PAIR of GC2 Golf car batteries (About the same "Footprint" as a group 24 but taller) These are 6 volt which you wire like this -6V+==-^6V+==12 volt to rev (the = is a wire) around 220 amp ours more or less depending on specific version and brand (210-230 is common) and you can use fully half. that's 4 times what a single Group 29 gives you.
Now in addition to the above the batteries come in 3 different types.
True DEEP CYCLE GC-2 Golf Car batteries are often flooded wet cell. This means you add a bit of distilled water from time to time to fill them up to 1/8" or so BELOW the bottom of the filler tube. you also need to frequently clean.> Go with monthly checking of fluid level at first. And quarterly once you find out how often to add. As they age they need more frequent watering.
Maintenance free. or Sealed Valve Regulated Lead Acid. you do not add water or anything else. Most MARINE/rv or MARINE/deep cycle are of these type. they are NOT maintenance free as you need to clean (NOTE Starting batteries not otherwise discussed are also often this type(
AGM.. A sub set of Maintence free "Absorption Glass Mat" is a "Starved electrolytic" Basicaly a moist fiberglass cloth replaces the liquid so if you have to mount 'em upside down or on end or side. No problem. These are also physically rugged and able to take serious abuse
Optima.. A sub set of AGM. spiral plates so only about 60% of the capacity of the same size flat plate battery.
Cost generally increases as you go down the list.
Finally there are some new formulations like LiFePO4 (Lithium Iron Phosphate)
Right now these are most expensive of the list but the price is in free fall. If you go with one I'd recommend either Battler Born or Bioenno power. A well designed LiFePO4 battery has a battery management (Charge controller) Built in
Bioenno (NOTE I may have flubbed the spelling) does not recommend using multiple in parallel (I have one small one) Battle Born does so if you plan on multiple go with them.
Now.. with These you can use over 90% of the battery (Like 99%) and unlike the lead acid the voltage remains near constant during discharge. They do run a bit "hotter" (Higher voltage) Battle Born has a "Deal" with Progressive dynamics to provide a converter matched to their product.
Some modern converters and inverter/chargers (I have one of those) can be "Adjusted" to match the product.
So far I like my LiFePO4.. NOTE: There are muliple Lithium formulations. some tend to "Flame on" (Catch fire due to thermal runaway) LiFePO4 is far less likely and the Battery Management system helps to prevent it. HOWEVER they don't like COLD weather either.. Where as a good Lead Acid can go 10-20-30 or more BELOW zero (F or C don't matter) Lithium's like to be above freezing for proper operation or so I'm told (have not tested, I bring my small one in for charging)
Hope this helps and good luck
Those battery systems sound like a good deal but not a lot of "Juice" in a single battery.
And now it's a boilerplate to save me typing.
Skibane
San Antonio, TX
Posted: 11/14/21 02:59pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, assuming those bigger batteries will fit in your particular battery compartment.
Be sure to measure your battery compartment before buying a larger battery.
Here's a link that shows the typical dimensions of various battery group numbers.
(Note that these are TYPICAL sizes - there is some variation among different brands.)
theoldwizard1
SE MI
Posted: 11/14/21 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
If you have the room, two 6V golf cart batteries, wired in series, is your best bet. The size is GC2.
The best brand is either Trojan or Rolls. These are expensive but top of the line !
Costco sells Interstate and Sam's club sells Duracell. Very good quality at very reasonable price. You can actually buy 2 of them about 50% more than 1 dual purpose/marine/RV battery. Two 6V batteries would store a lot more power than one 12V battery.
2112
Posted: 11/15/21 04:49am Link  |  Quote  |  Print  |  Notify Moderator
Not only is a group 31 larger, it's also heavier. It's difficult for me to get my 31 out of the basement. I don't want to do that again.
I've had good luck with a single group 27 Wal-Mart 27DC for $80. I get 5 years out of one with proper maintenance. We will sometimes overnight without power and this has served us well. We can watch satellite TV for hours on a 100W inverter and run the furnace for a few hours if needed.
Your best battery selection really depends on your expectations and how you plan on using it. Do you want it to power your propane fridge and lights for a few days or run your microwave?
Battery maintenance is an important part of how well your battery performs. My WFCO charger will kill my battery if I let it.
2013 KZ Durango 2857
Super_Dave
Harrisville, UT
Posted: 11/15/21 07:06am Link  |  Quote  |  Print  |  Notify Moderator
Jerry
Joel, I believe that Jerry has given you the best advice. It doesn't sound like you plan on boondocking or camping without hookups and just want 12v power when traveling or not connected. If you plan on going with just one battery, I think that I would choose a 27.
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
pianotuna
Regina, SK, Canada
Posted: 11/15/21 08:50am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
If you plan to boondock without shore power then buy the biggest meanest deep cycle battery that will fit.
If you are always on shore power, any battery will "fill the bill".
Regards, Don
 > House Battery
