RV.Net Open Roads Forum: Fifth-Wheels: Recommended must have for 5th wheel
 > Recommended must have for 5th wheel
goducks10
There
Posted: 11/15/21 08:46am Link  |  Quote  |  Print  |  Notify Moderator
Extended warranty.
speediq99
Arizona
Posted: 11/15/21 09:03am Link  |  Quote  |  Print  |  Notify Moderator
2022 F350 Diesel 4x4 Crew Cab
Trailer max weight 16800
Thank you
MC
ACZL wrote:
What tonnage truck do you have? Gas or diesel? Max weight of trailer? IMO, it's best we have this info to better inform you. I think tho, you may me asking about the 5er only, but if we have more info, we can better provide you w/ answers.
speediq99
Arizona
Posted: 11/15/21 09:08am Link  |  Quote  |  Print  |  Notify Moderator
Hi Russ,
My bad. I said 376 but It is a Grand Design Solitude 378mbs
Uvw 14344
Hitch 2686
Gvwr 16800
Lenght 40.2
MC
rhagfo wrote:
valhalla360 wrote:
This...make sure you have enough truck.
5th wheels tow great but not if you have a substandard truck.
Well if one took the time to look up that 5er it is a Grand Design Momentum 376TH, these are the specs.
UVW1 15,900 lbs
Hitch Weight 3,250 lbs
GVWR 20,000 lbs
Length 41' 3"
Height 13' 5"
I would hope the OP has at least a 350/3500 DRW.
ford truck guy
Pennsylvania
Posted: 11/15/21 09:54am Link  |  Quote  |  Print  |  Notify Moderator
Considering their other thread is asking what is the BEST SLIDER HITCH for the 6.5 bed, that tells me its a SRW .
NOW, I know that I tow a heavy fiver with my new SRW, BUT this trailer they are talking about has a DRY weight of 16,000# with a DRY hitch weight of 3,250#
So, I would say that the best option to het for your new trailer is a another new truck......
AT least MY combo starts off UNDER all of my numbers, and stays UNDER MOST of them, but more importantly, under the IMPORTAND ones... RAWR, tire capacity.
Sorry, I know you didn't ask about the truck, but I was lead into that conversation
2nd edit... Now you want to add a 50 gallon fuel tank into the bed. that's about another 425# of fuel into a 200# tank.?
* This post was edited 11/15/21 10:12am by ford truck guy *
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
theoldwizard1
SE MI
Posted: 11/15/21 09:59am Link  |  Quote  |  Print  |  Notify Moderator
Strong sun kills roofs !
Wash at least twice a year and a apply a UV resistant spray like 303 UV protectant. If possible store out of the sun.
theoldwizard1
SE MI
Posted: 11/15/21 10:01am Link  |  Quote  |  Print  |  Notify Moderator
goducks10 wrote:
Extended warranty.
I have yet to hear of anyone ho has had a GOOD experience with extended warranty !
MarkTwain
Northern, Ca. , USA
Posted: 11/15/21 10:11am Link  |  Quote  |  Print  |  Notify Moderator
goducks10 wrote:
Extended warranty.
Waste of MONEY.
dieseltruckdriver
Black Hills of SD
Posted: 11/15/21 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
If you don't have auto levelling, I would highly recommend Anderson levelers.
We both loved them in our previous 5er. The new one has auto levelling and I don't think I will ever own an RV without it.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
valhalla360
No paticular place.
Posted: 11/16/21 02:54am Link  |  Quote  |  Print  |  Notify Moderator
Thank you
MC
Single or dual rear wheel...what is the payload on the door sticker?
This trailer could easily be upwards of 4,000lb on the hitch. I wouldn't want to pull that without moving up to a dually.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
TXiceman
Full Time RVer
Posted: 11/16/21 06:00am Link  |  Quote  |  Print  |  Notify Moderator
With the trailer you are buying, I sure hope you are going to get a DRW truck and not a SRW truck. A DRW truck will have a longer 8' bed unless it is a Ram 3500 DRW with the Mega Cab.
Every day we see people pulling into the campgrounds with SRW trucks and too much trailer. There is fellow here now with a 3/4 ton GMC and a 41' Solitude.
Ken
Amateur Radio Operator.
