RV.Net Open Roads Forum: Tech Issues: Lithium battery as starter assist
 > Lithium battery as starter assist
ramsaymike
Bobcaygeon ON
Posted: 11/15/21 09:36am Link  |  Quote  |  Print  |  Notify Moderator
I am considering changing out the house batteries with a single 100 ah lithium. In certain conditions I need to use the battery combiner dash switch to start the engine. Would this still be possible with the lithium battery? Thanks.
2014 Cedar Creek Cottage CRS
2007 Coachmen Concord M275 (6.0 diesel)
2oldman
So Cal
Posted: 11/15/21 09:42am Link  |  Quote  |  Print  |  Notify Moderator
What are the existing house batteries? Starters can take hundreds of amps.
ramsaymike
Bobcaygeon ON
Posted: 11/15/21 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Starter batteries (2) are conventional lead acid. I generally see max current is 2c so I think 200 amps 3-5 seconds for the li battery I am looking at. I don't know if the BMS would protect the protect the battery or I would risk damage.
Original house batteries are deep cycle lead acid.
2oldman
So Cal
Posted: 11/15/21 09:50am Link  |  Quote  |  Print  |  Notify Moderator
Then you'll need an Li battery that can deliver 2c. Not all can.
pianotuna
Regina, SK, Canada
Posted: 11/15/21 12:02pm Link  |  Quote  |  Print  |  Notify Moderator
The short answer is NO, unless there is a massive Li battery bank.
Why? The battery management systems on Li batteries limit the output to about 100 amps (some are more some are less). The starter draws hundreds of amps.
You could do what you want with an SiO2 battery, which are able to do a 4C rate continuously, and 9 C for 5 seconds (400 amps from a 100 amp-hour battery)
Regards, Don
time2roll
Posted: 11/15/21 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
Yes. However 100 Ah might be light for general use and for the boost start. Worst case it will not work and you will have to do something else to get started.
675w Solar pictures back up
2oldman
So Cal
Posted: 11/15/21 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
Battleborn will allow a 200a surge for 30 seconds.
pianotuna
Regina, SK, Canada
Posted: 11/15/21 01:32pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the info 2oldman
200 amps may not be enough to run a starter motor. On my Elantra--sure, on a diesel...iffy.
2oldman
So Cal
Posted: 11/15/21 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
No, but as a bit of help to chassis batteries, perhaps. If it were my rig I'd go with 2.
Posted: 11/15/21 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
Somethng many are forgetting is the voltage on LiFePO4 is slightly higher than Lead acid. to the Li's may charge the starting batteries
I have a little LI battery pack.. designed specifically for jump starting. the battery is TEN that's right 10, amp hours.
Never tried it on a motor home
but a 4lung car.. Varroom
