RV.Net Open Roads Forum: Fifth-Wheels: Bed cover for F350 with fifth wheel hitch
 > Bed cover for F350 with fifth wheel hitch
speediq99
Arizona
Posted: 11/15/21 10:32am Link  |  Quote  |  Print  |  Notify Moderator
Hello,
Can anyone recommend a bed cover that will work on an F350 SRW crew cab with a 5th wheel hitch and a diesel bed mounted expansion fuel tank. Considering any fuel tanks at the moment that will work with any bed covers. I just want stuff out of sight when 5th wheel is not attached.
I have used soft tonneau covers before and they are OK. They just shake around a lot but this may be the only option.
MC
corvettekent
Marysville, WA
Posted: 11/15/21 10:53am Link  |  Quote  |  Print  |  Notify Moderator
I would recommend not using a bed cover.
2007.5 GMC Dually EC/LB, LMM. Banks IQ, Speed Brake, Six Gun. B&W Turnover Ball, Companion Hitch, Amp power steps. Hadley Air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT and four 6 volt batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
MFL
Midwest
Posted: 11/15/21 10:58am Link  |  Quote  |  Print  |  Notify Moderator
I have used Access soft covers for many years. They are rugged, fit good, and easy to install.
I am anything but a weight cop, but I see you mention a bed mounted diesel tank. Just not going to work with your FW, and SRW!
Thermoguy
Graham, WA
Not sure about the fuel tank but I think they make Tri-Fold that will work. I have a roll up and it works great, but no fuel tank. The 5th wheel hitch is not the problem, I think they are all lower than the bed rails.
I think a bed cover is a must have for any truck unless you constantly haul trash or dirt.
kmac7800
Richland
Posted: 11/15/21 11:06am Link  |  Quote  |  Print  |  Notify Moderator
You can try a canister type of bed cover (google it). You might even find someone's youtube video where he had one installed and a combo tool-box/fuel tank installed that used the empty space under the canister. However I do not remember if he had a long bed or a standard bed.
You could also (if you do not already have the bed fuel tank) get the bigger OEM fuel tank replacement and not take up room in your bed.
Good luck!
//KMac
Cummins12V98
on the road
Posted: 11/15/21 12:55pm Link  |  Quote  |  Print  |  Notify Moderator
100% agree!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
GottaRunGottaCamp
East of Atlanta, Ga.
Posted: 11/15/21 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
100% agree!!!
X2, I have a Bakflip folding cover and it makes it very difficult to hook up a fifth wheel
2016 F350
2019 Heartland Torque TQ-371
Thermoguy
Graham, WA
Posted: 11/15/21 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
That's because you have a BakFlip - if you had a roll up cover, it would be a different story...
* This post was edited 11/15/21 04:15pm by an administrator/moderator *
ford truck guy
Pennsylvania
Posted: 11/15/21 02:09pm Link  |  Quote  |  Print  |  Notify Moderator
I have towed 3 different fivers with my Roll-N-Lock retractable cover.... What a nice option to have on the truck... When not towing, the cover is closed and mostly water proof. But more importantly, it locks. Out of sight, out of mind when it comes to thief's .
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
JKJavelin
Milwaukee, WI
Posted: 11/15/21 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
FWIW, I have the Bakflip Fibermax 4 section on my Ram std bed. When towing, 3 sections are folded and latched onto the 4th section. As soon as I unhitch, the bed gets covered up. Works great.
JK
* This post was edited 11/15/21 02:45pm by JKJavelin *
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS
Titan Disc Brakes
Trailair pinbox
Morryde SRE-4000 w/ wetbolt kit
Demco Hijacker Autoslide 18k
570 watts of Solar
2017- 21 Nights
2018- 75 Nights
2019- 138 Nights
2020- 72 Nights
2021- 122 Nights
