RV.Net Open Roads Forum: Tow Vehicles: Calling weight police - help
Search only in Tow Vehicles
 > Calling weight police - help
Page of 6
speediq99
Arizona
Posted: 11/15/21 10:39am Link  |  Quote  |  Print  |  Notify Moderator
Hello,
I am in the process of getting a new setup, truck and 5th wheel. Truck is a 2022 F350 King Ranch 4x4 SRW short bed Diesel. Fifth wheel is 2021 Solitude 378mbs. I am also planning to add Summo spring helpers as I used these before with my F150 and they worked great.
There will be 2 Adults and a 60 lb dog traveling most of the time. Nothing on truck bed except for a few chairs. We may add an expansion gas tank down the road 30-40lbs in the bed. It is not a must have.
I would like to avoid the duallies but I don't want to be a fool either.
Can someone give me some more feedback on this topic? We take delivery of the truck soon as well as fifth wheel so nothing 8s in stone at the moment.
MC
jdc1
Rescue, Ca
Posted: 11/15/21 10:41am Link  |  Quote  |  Print  |  Notify Moderator
Get an 8' (regular bed) bed truck.
corvettekent
Marysville, WA
Posted: 11/15/21 11:00am Link  |  Quote  |  Print  |  Notify Moderator
I would recommend getting the dually with the 8' bed. The dually will give you a more stable ride and you won't have to worry about the weight after you add the extra fuel tank.
2007.5 GMC Dually EC/LB, LMM. Banks IQ, Speed Brake, Six Gun. B&W Turnover Ball, Companion Hitch, Amp power steps. Hadley Air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT and four 6 volt batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
Quartzsite, AZ
Posted: 11/15/21 11:29am Link  |  Quote  |  Print  |  Notify Moderator
I don't like dually trucks but sometimes the safe way is to buy one.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Second Chance
Wherever...
Posted: 11/15/21 11:34am Link  |  Quote  |  Print  |  Notify Moderator
Loaded for travel, the Solitude 378MBS will put about 3,800 lbs. on the pin. Make sure the truck has that kind of payload left over after subtracting the weight of the hitch, occupants, gear, etc. Personally, I would only pull that trailer with a dual rear wheel truck.
Rob
U.S. Army retired
2020 Solitude 310GK-R
2012 F350 CC DRW Lariat 6.7
Full-time since 8/2015
ford truck guy
Pennsylvania
Posted: 11/15/21 11:53am Link  |  Quote  |  Print  |  Notify Moderator
My brother in law just took delivery of his 2022 F350 lariat, 6.7, 4x4 , Short bed.. his payload sticker is 3600# as the truck sits.....
Deduct the fifth wheel hitch 150#... wife - 120#- dog -60#.. that's 330# to deduct off the 3600 before you even get to the trailer....
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Posted: 11/15/21 11:55am Link  |  Quote  |  Print  |  Notify Moderator
Depends what you mean by "2 Adults and a 60 lb dog traveling most of the time". 2 adults and a dog don't mean squat when figuring payload. Do you mean most of the time as in sometimes, there will be different number of people and dogs or you'll be traveling most of the time?
If I was spending the princely sum, that tht truck will cost you, I'd want to get it right too!
If it's a daily driver/commuter/whatever mostly and a tow rig for that trailer occasionally, I'd go srw 100%.
If the scales are flipped and that truck's primary goal in life will be to tow a big 5ver, I'd 90% get a dually.
2017 Heartland Torque T29
Cummins12V98
on the road
Posted: 11/15/21 01:06pm Link  |  Quote  |  Print  |  Notify Moderator
Sad when you have to add any type of helpers to handle a RV instead of buying a RV that is the truck can HANDLE SAFELY.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Mike134
Elgin, IL
Posted: 11/15/21 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
The weight police recommend a dually if you tow any thing more than a pop-up, " because you can never have enough truck" did you expect any other answer?
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
Me Again
Sunbird(Wa)/snowbird(Az)
Posted: 11/15/21 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
Rob
How do you get from 2686 dry pin weight to 3800 load. That is about 1/2 of the carrying capacity of the of the trailer. Do you really think that much will go on the pin.
Taking dry weights it has 18.7% dry pin weight. Carry the percentage forward to 16800 GVWR of the trailer give 3146 lbs of loaded pin weight.
If pin weight increases to 20 percent load, the 3360 would be the pin weight fully loaded.
Now we need to talk about generators and washer/dryer. W/D prep is in the nose, and generator well ahead of the axles.
I made this work with my 16K 39'4" Bighorn because it had a 2435 dry pin weight with our 2015 RAM SB 4X4 3500 SRW with 11,700 GVWR and 7K RGAWR. And we were loaded heavy as full timers at that time.
2021 F150 2.7 Ecoboost - Summer Home 2017 Bighorn 3575el. Can Am Spyder RT-L Chrome, Kawasaki KRX1000. Retired and enjoying it!
Page of 6
