RV.Net Open Roads Forum: Tow Vehicles: Calling weight police - help
Search only in Tow Vehicles
 > Calling weight police - help
Page of 6
Cummins12V98
on the road
Posted: 11/16/21 10:09am Link  |  Quote  |  Print  |  Notify Moderator
ford truck guy wrote:
Cummins12V98 wrote:
ACZL wrote:
Good move OP ! Walaby said it best as we were in same boat few years back as we too thought we had 'nuff truck..........nope. Went from a '15 F350 SRW to a '17 F350 DRW. Stinks in snow, but tows great !
You should never be in snow!
HA HA.. SOME of us don't/can't winter in the WARM south.... [emoticon]
We are delayed getting out of here and it SUCKS!!!!
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
ford truck guy
Pennsylvania
Posted: 11/16/21 11:07am Link  |  Quote  |  Print  |  Notify Moderator
Wait, what ??
I thought you left back in October.. You sent me a note back in the end of October saying you were trying to leave the next day, everything ok?
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Cummins12V98
on the road
Posted: 11/16/21 11:29am Link  |  Quote  |  Print  |  Notify Moderator
Technical difficulties.
alexleblanc
Shediac N.B
Posted: 11/16/21 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
you did the right thing, my truck would most likely have a similar payload to what yours would of had and with out new GD Reflection 311BHS i'm running down the road around 14500lbs and around 2800lbs on the Pin - it is extremely comfortable and a very stable setup but i also know that this is about as much as i would feel comfortable with a SRW.
TV - 2017 F350 CCSB SRW Platinum 6.7 + 5er - 2021 Grand Design Reflection 311 BHS + B&W Companion
FishOnOne
The Great State of Texas
Posted: 11/16/21 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
Me Again wrote:
Hey Ron, is your truck still in the hospital?
We all know that's impossible so don't be letting the cat out of the bag.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"200k Mile Club"
'16 Sprinter 319MKS "Wide Body"
speediq99
Arizona
Posted: 11/16/21 04:06pm Link  |  Quote  |  Print  |  Notify Moderator
It looks like this may be a good thread to ask about gear ratio given how many here run duallies.
I have 3.55 or 4.10 option for the F350 Dually. Towing 16k.
I like running around at 65-70mph.
Read somewhere that 4.10 mpg really suffers after 65mph. No trying to save on fuel as much as trying to preserve range. I also enjoy a quite ride.
A 10 speed will allow me downshift with a 3.55 to get the rpms higher for the right torque.
Should I go with 3.55?
Would a 3.55 climb a 6% hill just as fast as a 4.10?
I ordered the truck with 4.10s but I may end up using it 30-40% of the time to travel empty. Thinking about changing to 3.55or.
Any suggestions?
MC
Gener8s1
Toronto
Posted: 11/16/21 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
For my money I would go long box DRW. I know the long truck ca be a pain at the grocery store but the better ride is well worth it. I don’t think with the 350 you will need spring helpers. These trucks are made to haul. I pull a 45’ Toy hauler with my 3500hd GMC DRW. just rests on the helpers and rides like a dream.
Cummins12V98
on the road
Posted: 11/16/21 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
Yes it's still there and since Covid is so bad I can't even visit it.
FishOnOne
Posted: 11/16/21 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
Headgasket?
valhalla360
No paticular place.
Posted: 11/17/21 12:34am Link  |  Quote  |  Print  |  Notify Moderator
Per the Ford towing guide, the 3.55 is rated for at least 31,300lb 5th wheel, so you aren't even close to the limits. The 4.10 only increases that to 34,700.
With the 10 speed, it will just pick a different gear if you are climbing a grade to result in the same overall gear ratio between the engine and wheels...the engine will never know the difference and you likely won't either as the engine will be turning the same RPM.
4.XX rear ends made a lot of sense back in the days of 3 speed transmissions, there was so much space between gears that when towing, you often wound up either lugging the engine in top gear or running high RPM in a too low gear. With 10 speed transmissions, it can always find a gear that puts the engine in it's ideal RPM range for the load.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Page of 6
