RV.Net Open Roads Forum: Class A Motorhomes: A/C Issues??
 > A/C Issues??
CA Traveler
The Western States
Posted: 11/20/21 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Repairs not authorized by Tiffin may have the warranty denied ie mobile tech.
2014 Grand Cherokee Overland
Bob
Alex and Tee
Jacksonville , FL
Posted: 11/20/21 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
No repair was done and the mobile tech was from the dealer I bought it from.
All ductwork in tact.
Alex & Teresa
2022 Allegro Open Road
2021 Colorado 4x4
Ray,IN
IN, USA
Posted: 11/20/21 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
Alex and Tee wrote:
Measurements done with a digital thermometer set on house mode. Will invest in some reflective shades for the front window. Front of coach is primarily black so I’m sure that isn’t helping much.
To obtain the best heat shield it should be on the OUTSIDE of the window.
And so, my fellow Americans: ask not what your country can do for you — ask what you can do for your country.John F. Kennedy 20Jan1961
dougrainer
Carrolton, Texas
Posted: 11/29/21 12:51pm Link  |  Quote  |  Print  |  Notify Moderator
THERE IS NO WAY ANY RV ROOF AC WILL PUT OUT 28.8 DEGREE COLD AIR. PERIOD. The best it will do is around 39 to 40 degrees in lower ambient temps. Besides, IF it could put out lower than 40 degree temps the Freeze thermister would shut the compressor off. There seems to be a BIG problem with how you and this so called tech are using their Temp measurement devices. One thing that will cause a problem is IF the bad AC was replaced. AND they did not install the separating gasket. That would cause the cold air to be pulled back into the AC unit and cause a lack of air volume. It could have happened at Tiffin when it was built, but I have never seen the separator gasket missing from the OEM. Doug
dougrainer
Carrolton, Texas
Posted: 11/30/21 10:45am Link  |  Quote  |  Print  |  Notify Moderator
OK, you should have the RVP Coleman 15k Heat Pump. At 85 degrees outside ambient, the TOTAL amp draw will be 14 amps to 14.3 amps. Hi Fan. Discount the 2.5 amps for fan draw, your compressor should be pulling 12.0 amps. NOT 9 amps. Where did this so called tech measure the amp draw and did you see what kind of amp draw tool he used? At 9 amps, that would indicate a charge problem. But I doubt any of his diagnostics is correct or accurate. I still lean towards the separator gasket missing or not installed correctly. You HAVE to pull the top unit to verify this. Click this link and scroll towards the bottom where he has the AC on its side. That center gasket is the seperator gasket. Doug
https://www.amazon.com/Steele-Rubber-Products-Mounted-Gasket/dp/B07TW7QY16
Alex and Tee
Jacksonville , FL
Posted: 11/30/21 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
I have a more experienced tech scheduled to come out on the 10th. I’ll wait until he gets there and see what his findings are. I have zero confidence in what the other guy did and I told the mobile service manager that as well as whatever he used to measure temps was either no good or horribly out of calibration. At 81 degrees outside temperature this unit struggles to get the coach to 77 degrees. Just runs constantly.
You just can’t find good help these days.
CA Traveler
The Western States
Posted: 11/30/21 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
Alex, I'm so happy for you as you're learning how to spell RV.
Cheers
Alex and Tee
Jacksonville , FL
Posted: 12/10/21 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
A/C update
Service tech came today. Outside temperature was 58 degrees. Tech said unit was pulling 9 amps. Said it should be around 7. Recommending unit replacement. It’s under warranty so no skin off my nose but seems like an extreme resolution. Still going to invest in a set of window covers to cover the windshield and side windows.
He was also able to quickly switch the wires on my Spyder control so the front and rear now operate properly.
dougrainer
Carrolton, Texas
Posted: 12/11/21 11:03am Link  |  Quote  |  Print  |  Notify Moderator
Alex and Tee wrote:
A/C update
AS you stated, no skin off your nose. Plain fact is RVP will replace the Unit. BUT, YOUR PROBLEM WILL NOT BE FIXED BY A NEW UNIT. So, it will continue to be a time drain and waste of time for you to get your unit properly fixed. Hopefully when they remove the old unit, they will check for the separation gasket, see that it was missing or not installed correctly, INSTALL that gasket on new unit and if so, your "new" unit will then function as designed. Then everyone except the Technician will think the old unit was faulty. Doug
PS, after I had more time, I crunched the numbers. My previous numbers were a guess. Your 15k (452X4*8XX2) will pull 11.8 amps(compressor ONLY) at 95 degrees. I will go with 60 degrees ambient since it appears NOBODY at your end has or can read a correct Thermometer reading. So at 60 degrees ambient the compressor should draw 7.6 amps. Since NONE of the Techs seem to be able to comprehend what they are doing, lets assume it IS 9 amps. That tells me it is pulling a little over 1 amp HIGHER than spec, which will NOT cause a great loss of cooling. 9 amps would indicate an overcharged system, I have NOT seen an overcharged RV AC unit in years and hundreds of AC's I have worked on. When they come back, ASK about the SEPARATOR gasket if you have not already. If they give you a blank look or do not seem to understand your question----YOU HAVE YOUR ANSWER.
* This post was edited 12/11/21 04:36pm by dougrainer *
Alex and Tee
Jacksonville , FL
Posted: 12/12/21 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for your insight. I will be sure to mention it when they come to install the replacement.
 > A/C Issues??
