RV.Net Open Roads Forum: Fifth-Wheels: Lippert auto leveling system
 > Lippert auto leveling system
philh
Belleville MI
Posted: 11/16/21 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
Truly sad you are sent away not knowing how to hitch and unhitch you’re RV.
I am sure there are good YouTube videos that match your system.
Dealership showed me how to manually raise and lower the legs, but did not explain some of the automated menu items.
In defense of the dealership, we spent almost 45 minutes straightening out the cable/satellite hookups. Factory had miswired it, and it was only because I didn't understand the labels or their explanation, they started tracing wires.
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 11/16/21 04:43pm Link  |  Quote  |  Print  |  Notify Moderator
Ours is the Black Control unit just like Ford Truck Guy and he is 100% correct.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Cummins12V98
on the road
Posted: 11/16/21 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
I use the manual mode on mine exclusively as I don't like how the front of the RV drops so much with the heavy pin weight i have in the Auto Mode.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
obie311
Aux Arcs
Posted: 11/16/21 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
Here's the critical part if you haven't already found it:
Hitch Recognition
1. Turn on the touch pad.
2. Push the “UP” arrow (Fig. 5A) to scroll to “Auto Reconnect” option on LCD screen.
3. Push "ENTER" (Fig. 5B). The rear jacks and middle jacks (if equipped) will retract first, then the front jacks will extend to raise the trailer to the height where the auto level sequence was started.
Of course like a lot of things with our trailers, nothing is perfect. You may have to tweak the height a little bit manually to match your hitch.
One other thing is to properly calibrate "Level" to your system. If you find yourself at a level or nearly level campsite, take time to calibrate the level.
I place a carpenters level on the countertop and floor to get a reference.
You may have to manually tweak the legs to get it level if the previous Auto Level setting is wrong. Just remember not to get your wheels above the parking surface when you level the trailer.
* This post was edited 11/24/21 04:49pm by obie311 *
StirCrazy
Kamloops, BC, Canada
Posted: 11/17/21 08:37am Link  |  Quote  |  Print  |  Notify Moderator
it only works under a spicif situation also. I believe your front end has to drop first once you push auto level, then if you hit the two outside arrows it will go back. unfortunuatly it rarly works for me as it always starts off the wrong way. I wish they would have a seperat button to actualy set the hitch hight instead of relying on which way the frong jacks move first.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
NJRVer
NJ
Posted: 11/21/21 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for posting that!
