RV.Net Open Roads Forum: Class C Motorhomes: Which fridge would you choose?
 > Which fridge would you choose?
glennts
Corpus Christi, Tx
Posted: 11/16/21 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
My Norcold N641 with a 7 yr old Amish cooling unit may have died. Started to get instant NoCo, dealt successfully with this in the past, but this time, even after a new board, cleaning the burner orifice, connections, testing the AC heating element, although there is not a repeat of NoCo there is no cooling. The outside of the boiler stack will burn you but the fins at the condenser top remain cool and the vertical pipe before the fins is hot but I suspect this is from rising hot air from the AC element. So apparently there is no circulation. Spent 6 mos to 9,000' and perhaps that messed up the coolant process??? Running a straight to AC for 24 hrs test to confirm it's the cooler.
In the mean time looking at 12v only units... plenty of solar and lipo4 to support it.
A new 7.7 Everchill is $849 + shippng.
A scratch and dent(door)8.2 Norcold N8DC is $1450 but can be had for $825 + shipping.
The Norcold is a perfect fit for the N641 space which gives it an edge.
Which would you choose?
bgum
South Louisiana
Posted: 11/16/21 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
Norcold if not damaged very bad.
pianotuna
Regina, SK, Canada
Posted: 11/16/21 05:21pm Link  |  Quote  |  Print  |  Notify Moderator
Hi definitely 12 volt.
I don't think the make is important-but a drop in replacement makes life easier.
I would go for SiO2 batteries, unless you roll your own Li and NEVER camp in coolish weather.
Regards, Don
bobndot
Posted: 11/16/21 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
I agree the size that fits is the easiest install. Look into the amp draw of each model, then decide.
valhalla360
No paticular place.
Posted: 11/17/21 12:50am Link  |  Quote  |  Print  |  Notify Moderator
So far (1.5yrs full time), we are quite happy with the everchill that came with our rig.
The big advantage is it has drastically more interior space for the same size hole in the wall. It's a plus that it cools more quickly but not really a deal breaker either way.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
bobndot
Posted: 11/17/21 05:55am Link  |  Quote  |  Print  |  Notify Moderator
At what voltage do these 12v fridges cut off at ?
I can see them cutting off at 11.8v to protect Wet cells / AGM’s but other batteries like lithium or Si02 allow them discharge lower.
My question is, would a fridge with a lower cut off be an advantage or better option using these types of batteries ?
Also, is it necessary to need a specific charger or converter to use with the Si02’s.
I have a PD4000 , not sure about charging specs of Si02’s.
Anza-Borrego Desert SP area
Posted: 11/17/21 08:20am Link  |  Quote  |  Print  |  Notify Moderator
I tried a non-drop in a while ago. You don't want to try that too. Lots of work.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Sandia Man
Rio Rancho, NM
Posted: 11/17/21 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Since pricing is similar due to scratch and dent Norcold, I would stick with absorption RV fridges as we have had excellent service from both Dometic and Norcold versions. We made sure over several rigs and 3 decades to purchase rigs where fridge was not in a slide. Been fortunate enough that we have never had a cooling unit go bad, even on fridges that were 20 years old.
The primary reason I would consider going with a 12Vdc or 120Vac compressor fridge is cost, I could literally buy 5 residential fridges for what it would cost ($5200 at PPL not including install) to replace our Norcold. With install and taxes nearly $6K is a bit tough to swallow, for certain we would go with an Amish cooling unit before resorting to compressor based versions.
glennts
Corpus Christi, Tx
Posted: 11/17/21 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
It's gone. You don't suppose someone saw an opportunity when the scratch and dent Norcold was mentioned in this thread. Had wondered about the wisdom of posting but it's spilled milk now.
Lesson learned.
pianotuna
Regina, SK, Canada
Posted: 11/17/21 02:15pm Link  |  Quote  |  Print  |  Notify Moderator
Lesson learned.
I don't think anyone would order a spare fridge. There are thousands of folks who have fridge failures.
