RV.Net Open Roads Forum: Fifth-Wheels: MorRyde IS is finally happening
 > MorRyde IS is finally happening
Page of 7
Cummins12V98
on the road
Posted: 11/20/21 07:55am Link  |  Quote  |  Print  |  Notify Moderator
I highly doubt they even offer the IS with drum brakes.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Jim-Linda
Livingston, TX
Posted: 11/20/21 08:59am Link  |  Quote  |  Print  |  Notify Moderator
Don't know about now but when we had them installed in 1998 we had 33/8 drum brakes on 3 axle with no issues. Don't believe disc were in picture.
BarneyS
S.E. Lower Michigan
Posted: 11/20/21 09:13am Link  |  Quote  |  Print  |  Notify Moderator
ford truck guy wrote:
Life is Good ! ! Love those moments
* This post was edited 11/19/21 07:31am by an administrator/moderator *
WOW, you musta said sum reel bad chitz.
Yea, I don't think I did ???? perhaps a mod being a bit grumpy ??? I don't remember
Nope, not a grumpy mod at all. I took out a quote that was entirely unnecessary and only made the page longer. I did not touch anything you typed.
Very frequently, when you see that "edited" comment, it was because the person was replying to a comment immediately above his post and therefore no "quote" is needed. It just makes the page longer and we have to see the same thing again.
In the case of multiple quotes as in this post of mine, they are there and necessary for context because of a new page and it is somewhat farther down the thread. That is not the case when you are replying to someone immediately above you.
Barney
Not towing now.
ford truck guy
Pennsylvania
Posted: 11/20/21 11:08am Link  |  Quote  |  Print  |  Notify Moderator
THANKS for the explanation Barney,
We ALL know there is someone here that indulges in over moderating ( NOT YOU ) .. I always have to wonder . . . . After all,I wanna be on the "GOOD LIST" for Santa...[emoticon]
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
ford truck guy
Pennsylvania
Posted: 11/20/21 11:12am Link  |  Quote  |  Print  |  Notify Moderator
Lantley wrote:
JKJavelin wrote:
spoon059 wrote:
Curious what this costs? I had a spring break recently on a trip. It could have been substantially worse, but makes me worry now.
I believe that the 7K IS system is now running AROUND $6500.00 ? I am sure someone who just purchased can correct me.
the cost of NO MORE WORRIES -$ PRICELESS
MY OPINION is that it is worth every penny on a RV that will be around, if your planning on getting rid of it in a couple years, probably not...
$6500 I think that to much can somebody confirm the price ?
Sounds pretty steep. I got a quote from them about a year and a half ago, something like $3600. They also did rally specials knocking a few hundred off.
But I guess those days are over...
JK
Are these price quotes with or without disc brakes?
Is $6,500 with disc brakes and $3,600 without disc brakes?
That IS the 8K IS AND Kodiak Disc Brake system... I believe the IS alone is in the ballpark of $3500 - $4000 ???
Lantley
Ellicott City, Maryland
Posted: 11/20/21 11:56am Link  |  Quote  |  Print  |  Notify Moderator
JUst to clarify disc brakes installed are a $3,000 or so item and IS appears to be a $3,500.00 item. $6,500.00 total which quite and expenditure but I imagine it worth it in the long run if you travel frequently far and wide.
Personally disc brakes are a must have and IS is also a great upgrade if you use your RV frequently
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
Cummins12V98
on the road
Posted: 11/20/21 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
YA DON'T SAY!!!
Cummins12V98
on the road
Posted: 11/20/21 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
If you are happy with your RV and plan to keep it the IS WITH disk brakes is WELL WORTH IT!!!!!!!
I don't plan on ever having a regularly sprung trailer ever again. MC Kendon Trailer has the Dexter Torflex and I dumped the junk springs and drums on my Boat Trailer for the Marine Version with EOH actuator.
* This post was edited 11/20/21 01:28pm by Cummins12V98 *
philh
Belleville MI
Posted: 11/20/21 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have the receipt in front of me, but 7k axle with disk brakes, a 2'x5' slide and a couple of smaller pieces, was about 8,500. They are scheduling over a year out right now.
Electric over hydraulic disk brakes takes a little getting used to. I used to drag the trailer brakes to gently slow down the rigs, can't do that with this set up. HOWEVER, when you need to stop RIGHT NOW, the rig stops RIGHT NOW.
lenr
Indianapolis, IN
Posted: 11/21/21 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
Agree that disk brakes take a little getting used to. In my experience there are two issues: The first problem is that all disc brake actuators have some delay while they build pressure. Secondly, I have found that the braking response isn’t linear. As said above, they work great (for me) on hard breaking or high speed braking. It’s the light, slow, braking that drove me crazy. Depending on the controller and/or actuator a light push on the brake petal may not send out enough voltage to even start up the actuator--thus no trailer braking. While Hydrastar is supposed to be one of the quickest, my biggest concern was a low startup voltage. I found with BrakeRite (now owned by Dexter) to have good, low, startup voltage. Not sure what MORRyde is currently using for an actuator—they used to use BrakeRite. One solution if using a 2015 or later Ford is to set up the brake “Aggressiveness” to Med or High. Since my older Ford doesn’t offer this setting, the only other option that I found was to install a Prodigy P3 set to Boost level B3. At that boost, a light touch on the petal gets the BrakeRite pumping with slight slowing. Once pumping it is very responsive to more aggressive deceleration. As with any controller it is important to set gain at a point where the wheels do not lock up. The B3 setting will show you right quick if you have too much gain. Full discussion of my experience: Google for my thread "Disappointed in Disc Brakes." https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/29930221.cfm
Page of 7
