RV.Net Open Roads Forum: Truck Campers: Understanding the generator wiring
 > Understanding the generator wiring
moonlitsouls
Everywhere
Posted: 11/16/21 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
Hey guys , so ive been doing some upgrades to the electrical system of my eagle cap 811 , im in the process of installing a victron multiplus inverter charger
As i learn more about the camper wiring and 12v electrical in general , i contacted eagle cap to ask them what the source was of two particular wires. They told me these two wires were actually coming from the generator
Ive attached a photo of these two wires , and a wiring schematic from eagle cap for reference ,
Shore power / generator power runs through a transfer switch and then to the ac panel
But , these two wires are not actually on the diagram (likely because its just an optional add on)
Here's what's confusing me
These wires from the generator were actually previous wired directly onto the battery (I've since moved them to pos/neg busbars
Apparently these wires turn ON the generator by way of the 12v switch located in my control panel section so to speak , its just the simple Onan start / stop switch to turn on the gen
So how does this work exactly ? The switch turns on the generator , but why do we need two 4awg wires running from the battery to the generator ?
the power from the gen should be going from the gen to the transfer switch to the ac panel
KD4UPL
Swoope, VA
Posted: 11/16/21 06:20pm Link  |  Quote  |  Print  |  Notify Moderator
Those wires are likely to power the starter motor to crank your generator to get it started. They have nothing to do with controlling it. They have nothing to do with it's output.
moonlitsouls
Everywhere
Posted: 11/16/21 06:23pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the reply , im also confused about the connection between the switch and the wires , is the switch wired to the gen itself , then the gen uses these wires to pull power from the battery to start up?
3 tons
NV.
Posted: 11/16/21 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
I think you may be over-thinking it a bit…JMO
You didn’t mention whether or not you have a onboard genny?…
If not:
Since the Victron has it’s own built-in ATS switch (priority, shore or gen power), consider simply re-routing your shore power cord to the Victron, then from the Victron to the Main panel…
If so: Re-route the Shore power / Genny ATS output from the main panel to the Victron (and complete as mentioned above)…
Having said that, with an inverter you may also want to consider adding a sub-panel so that the inverter cannot inadvertently power up the OEM converter-charger (resulting in a’round-robin’ affair…), refer (passive power sensing-switching), water heater (or say, other wasteful consumers) etc…
Feel free to PM me for more ideas
3 tons
moonlitsouls
Everywhere
Posted: 11/16/21 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
If not:
3 tons
Hey 3 Tons , yes its an onboard onan generator , i included a wiring schematic.
But i think i got it now , these wires simply power the starter motor to my generator , then the output goes through the transfer switch , all that made sense to me. It never occured to me the gen needed a power source to start up
pianotuna
Regina, SK, Canada
Posted: 11/16/21 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
Nice equipment choices.
Will you go the auto generator start route?
Regards, Don
moonlitsouls
Everywhere
Posted: 11/16/21 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
hello , i dont think so, id like to use the generator for only emergencies. I have almost 1000w of solar so im hoping that covers all my needs.
3 tons
NV.
Posted: 11/16/21 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
Wow!…How do you fit nearly 1000w on top of a truck camper??
3 tons
moonlitsouls
Everywhere
Posted: 11/16/21 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
3 tons
wait , you mean im not supposed to put them on top of each other? [emoticon]
3 tons
NV.
Posted: 11/16/21 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
moonlitsouls wrote:
3 tons
Oh, I think I get it - it’s in a sandwiched thermionic generator configuration, right??
3 tons
(p.s. my EC 995 would be so lucky - lol)
