RV.Net Open Roads Forum: General RVing Issues: Slide Support
 > Slide Support
1L243
Oregon
Posted: 11/17/21 01:06am Link  |  Quote  |  Print  |  Notify Moderator
Does anybody actually use a jack or support the slide when its out?
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 500 watt Solar 2000 watt Inverter, 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
valhalla360
No paticular place.
Posted: 11/17/21 03:37am Link  |  Quote  |  Print  |  Notify Moderator
Generally consider a bad idea...if the tires go flat, the supports will shove the slide up causing damage.
They are designed to sit unsupported.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Cummins12V98
on the road
Posted: 11/17/21 04:16am Link  |  Quote  |  Print  |  Notify Moderator
No need to.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
phil-t
Ogdensburg, NY
Posted: 11/17/21 05:23am Link  |  Quote  |  Print  |  Notify Moderator
Not god. There is always "movement" of the RV and supporting the slide will cause it to not "move" with the RV. That will wear the slide mechanism and cause failure.
2010 Winnebago Vista 32k on a 2009 Ford F53 22k chassis
JIMNLIN
Oklahoma
Posted: 11/17/21 05:53am Link  |  Quote  |  Print  |  Notify Moderator
Slide supports are from the era before our modern powered (gear/hyd) slide outs and were needed to keep the then called tip out or pull out level.
I guess its possible some of those old trailers are still in use but I can't imagine they sell very many of those old supports.
eHoefler
ozark mountains
Posted: 11/17/21 06:16am Link  |  Quote  |  Print  |  Notify Moderator
I have used them since 2010, actually have had a tire go down on that side with no
affect at all. When we stop for one night on a trip, I don't take the time to use them. when we setup for the duration, I install them with just enough pressure to keep them from falling out. The rig has less movement when used.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
2oldman
Nevada
Posted: 11/17/21 07:06am Link  |  Quote  |  Print  |  Notify Moderator
Not needed, but I see them a lot.
jdc1
Rescue, Ca
Posted: 11/17/21 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
Waste of $$$$
way2roll
Wilmington NC
Posted: 11/18/21 06:36am Link  |  Quote  |  Print  |  Notify Moderator
I would think if you need a slide support you have an issue.
 > Slide Support
