RV.Net Open Roads Forum: Class A Motorhomes: Jam nuts & extenders
 > Jam nuts & extenders
Lanie67
Posted: 11/17/21 09:42am Link  |  Quote  |  Print  |  Notify Moderator
I have a 99 Safari Serengeti I’m look for part number for drivers side (right thread) jam nut and extender. Any help would be great. I’ve tried bringing it to camping world, Napa and a axle and spring shop with no luck. thanks
wolfe10
Posted: 11/17/21 10:09am Link  |  Quote  |  Print  |  Notify Moderator
Welcome
Please tell us what the "Jam nuts and extenders" are used for/where they are located/picture if possible.
* This post was edited 11/17/21 10:32am by an administrator/moderator *
rgatijnet1
Posted: 11/17/21 10:36am Link  |  Quote  |  Print  |  Notify Moderator
I'm guessing but I think he is asking about the lug bolts with the added threads to screw on the lug nut that holds the simulated stainless steel wheel cover. In other words you remove on nut, remove the wheel cover, and then you can remove the lugs that holds the wheel on.
If that is the case, I would guess that a place that supplies truck chassis parts should be able to find what you need.
IAMICHABOD
Sunny So Cal
Posted: 11/17/21 11:50am Link  |  Quote  |  Print  |  Notify Moderator
If this is it E Baymay be the answer. Phoenix Ind makes a lot of them,Fellow Camper used these for his simulators.
Former El Monte RV Rental
Buying A Rental Class C
MountainAir05
New Mexico
Posted: 11/17/21 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
or these jam nuts
