RV.Net Open Roads Forum: Beginning RVing: Antifreeze NOT Bypassing the Water Heater
 > Antifreeze NOT Bypassing the Water Heater
Sped
Sterling, MA
Posted: 11/17/21 10:53am Link  |  Print  |  Notify Moderator
I got the red valve on bypass and the blue valve on winterize. It’s sucking up the pink juice and spitting it out the water heater drain on the outside of the camper.
These valves seem so basic, plastic, and sort of bombproof….
Can these valves break go bad?
Am I missing something obvious?
Dan
magicbus
Nantucket Island, MA
Posted: 11/17/21 01:54pm Link  |  Print  |  Notify Moderator
A photo would help. Are your pipes red for hot and blue for cold? The bypass valve should be a T-valve that connects blue to red to bypass, and blue to blue for normal operation.
Dave
Current: 2018 Winnebago Era A
Previous: Selene 49 Trawler
Previous: Country Coach Allure 36
Boon Docker
Posted: 11/17/21 02:57pm Link  |  Print  |  Notify Moderator
If it is a two valve system do the following below.
