RV.Net Open Roads Forum: Max Pressure Cold vs Hot Pressures - How Much Is Too Much
 > Max Pressure Cold vs Hot Pressures - How Much Is Too Much
Page of 6
Rollochrome
Fort Worth, Texas
Posted: 11/18/21 04:16am Link  |  Quote  |  Print  |  Notify Moderator
My Carlisle CSL 16's have a cold max pressure of 110.
I installed a TPMS the same day I bought them.
I read up on these tires and there was nothing about a hot max pressure from Carlisle. I contacted Carlisle and they said there was no "hot max" specified.
So on the maiden voyage with them, I watched the temps rise and rise above 110 to just under 120.
The tires on the sunny side were uniformly higher than the ones in the shade side understandably too.
I read elsewhere that a different manufacturer emphatically states on their website regarding trailer tires to NEVER bleed down HOT tires.
So it begs the question, how much hot pressure is too much? The TPMS system instructs to set alert levels that are pretty high.
What do you think is an acceptable pressure level hot relative to the cold max?
* This post was edited 11/18/21 09:53am by Rollochrome *
1999 Saved By Grace Alone Thru Faith Alone! Thank You Jesus!
2019 F-350 LWB 6.7 4wd XLT-FX4-3.31 on Michelin Defender LTX M/S
2022 3850BH Cruiser South Fork on Carlisle CSL 16
Cummins12V98
on the road
Posted: 11/18/21 10:22am Link  |  Quote  |  Print  |  Notify Moderator
You are well under temps that would be of concern.
Does your axle weights require the MAX of 110# ?
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Gooma
Iowa
Posted: 11/18/21 10:24am Link  |  Quote  |  Print  |  Notify Moderator
You are over thinking this.
Inflate the tires to the recommended cold pressure and forget about it. Check the pressure regularly when cold, cold being the ambient temp. 110 pounds at 30 degrees is not the same as 110 pounds at 90 degrees.
Rollochrome
Fort Worth, Texas
Posted: 11/18/21 10:28am Link  |  Quote  |  Print  |  Notify Moderator
gawr 7,000 LB each axle
gvwr 15,500
time2roll
Posted: 11/18/21 10:35am Link  |  Quote  |  Print  |  Notify Moderator
Max cold inflation is before you roll and before the sun hits the tire. This is good in all conditions. Once set correctly there is no reason for concern. If you have a drastic change in elevation or climate, feel free to reset the pressure again the next morning.
675w Solar pictures back up
Rollochrome
Fort Worth, Texas
Posted: 11/18/21 10:37am Link  |  Quote  |  Print  |  Notify Moderator
Roger Wilco
thx
jkwilson
Indiana
Posted: 11/18/21 10:59am Link  |  Quote  |  Print  |  Notify Moderator
Most TPMS manufacturers recommend high pressure alerts at 125% of cold pressure. You are way under that.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
Rollochrome
Fort Worth, Texas
Posted: 11/18/21 11:02am Link  |  Quote  |  Print  |  Notify Moderator
10-4
thx!
MFL
Midwest
Posted: 11/18/21 11:05am Link  |  Quote  |  Print  |  Notify Moderator
A tire only requires setting according to cold temperature, before towing, or setting in the sun. Yes, towing will add heat/pressure, no problem, if psi is set correctly.
The bigger problem would be way under inflated, from loss of psi, maybe causing tire to heat up/come apart, but then your TPMS should warn you first.
Jerry
way2roll
Wilmington NC
Posted: 11/18/21 11:23am Link  |  Quote  |  Print  |  Notify Moderator
Curious why you are setting to max. Your FW should have a recommended psi .
Page of 6
