RV.Net Open Roads Forum: Max Pressure Cold vs Hot Pressures - How Much Is Too Much
 > Max Pressure Cold vs Hot Pressures - How Much Is Too Much
Page of 6
Cummins12V98
on the road
Posted: 11/19/21 08:53am Link  |  Quote  |  Print  |  Notify Moderator
Over/under MAX has nothing to do with "PROPER" inflation. There is a reason for every tire there is a Load/Inflation chart.
Weigh your axles and add 5psi to what the chart recommends. This is per GY Tech support for when a person wants to use the brain GOD has given you instead of blindly airing to MAX sidewall pressure.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
JRscooby
Indepmo
Posted: 11/19/21 10:32am Link  |  Quote  |  Print  |  Notify Moderator
LOL. "Proper inflation"? Weigh axle, check chart. If the tires on the axle are equally loaded, that 5 lbs is over inflation. OTOH, if you have a 30/70 split, you could still have a tire underinflated.
way2roll
Wilmington NC
Posted: 11/19/21 11:00am Link  |  Quote  |  Print  |  Notify Moderator
Rollochrome wrote:
way2roll wrote:
Curious why you are setting to max. Your FW should have a recommended psi .
It does. It came with F rated tires that had a max psi of 100
I replaced them with G rated tires that have a max psi of 110 so I went with the tires max psi rather than what the trailer sticker specified based on the factory equipped tires
Ok, makes sense. Then your best option would be to follow the inflation chart from the manufacturer of your new tires.
MFL
Midwest
Posted: 11/19/21 11:01am Link  |  Quote  |  Print  |  Notify Moderator
I think some of the tire inflation, disagreement, is due to talking about many different types of tire use. What works for cars, trucks, DRW trucks, motorhomes, and trailers, is not comparing apples to apples.
Most put the proper tires on their tow vehicle, and adjust as needed for load. I see some people buying way more tire than their trailer needs, then reducing pressure, way below max, when they should have just purchased the proper tire needed for the load, and aired for the load.
Jerry
laknox
Arizona
Posted: 11/19/21 11:22am Link  |  Quote  |  Print  |  Notify Moderator
Rollochrome wrote:
My Carlisle CSL 16's have a cold max pressure of 110.
I installed a TPMS the same day I bought them.
I read up on these tires and there was nothing about a hot max pressure from Carlisle. I contacted Carlisle and they said there was no "hot max" specified.
So on the maiden voyage with them, I watched the temps rise and rise above 110 to just under 120.
The tires on the sunny side were uniformly higher than the ones in the shade side understandably too.
I read elsewhere that a different manufacturer emphatically states on their website regarding trailer tires to NEVER bleed down HOT tires.
So it begs the question, how much hot pressure is too much? The TPMS system instructs to set alert levels that are pretty high.
What do you think is an acceptable pressure level hot relative to the cold max?
I've seen temps on my fully-inflated E range tires approaching 150 on the sunny side, and that was loaded to well below the 11,360 GVW on my old Komfort, which was placarded for D tires. I run +/- 62 mph, so speed's not an issue. These tires are built for this, so just run 'em and check them daily. Get a temp gun and check them first thing when you stop. Check your truck tires, as well, and don't forget the hubs.
Also, if you tend to run well below your GVW, personally, I'd have zero issues with running at 100 psi. With the above-mentioned Komfort, I'd run 70-75 psi most of the time and only go to 80 when I was heavily loaded. Given that the rig was placarded for 65 psi D tires, I was well within load specs.
Lyle
2017 KZ Durango 1500 D277RLT
1936 John Deere Model A
International Flying Farmers 63 Year Member
Cummins12V98
on the road
Posted: 11/19/21 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
Hey run MAX I don’t care but there are people that like to use the brain GOD gave then.
Campinghoss@51
Windsor NC
Posted: 11/20/21 09:32am Link  |  Quote  |  Print  |  Notify Moderator
Folks worry way too much over simple things. Rving is suppose to be fun and exciting. I have been pulling for 50 years. I always set my tires to max inflation as the tire states. I may be jinxing myself but the only tire trouble I have had was the valve stem failed while I was backing into a site and the tire went flat. I expect a lot of tire failures are due to under inflation and the tire running too hot.
I am not knocking those who weigh, adjust psi regularly just expressing my thoughts.
Camping Hoss
2017 Open Range 3X 388RKS
2017 F-350 6.7 with hips 8'bed
Lucky & Lucie
MFL
Midwest
Posted: 11/20/21 10:05am Link  |  Quote  |  Print  |  Notify Moderator
^ Agree, simple is good!
Normally, an OEM RV trailer tire has just enough capacity to cover the trailer weight when it is fully loaded. That capacity is usually at max sidewall psi.
When things change, is when the owner decides to go up in rating/capacity/higher psi max. One size, say D rated to E is a good thing if D is right at the edge. In this example, on an ST tire, you still can't go wrong with max pressure, or close to it. The problem comes, when the owner thinks he should change from Ds to Gs, and use only 2 thirds of max. A heavy tire, with low psi is going to have more rolling resistance, and run hotter.
Jerry
Sjm9911
New Jersey
Posted: 11/20/21 10:45am Link  |  Quote  |  Print  |  Notify Moderator
I always fill to max cold, im not weighing my TT everytime i load up for a trip. And each trip is diffrent. So, sometimes inflatable yacks, sometimes more gear for a longer trip. But im not weighing each time to set tire pressure. Of you travel where temps change dramatically, just recheck the tire pressure before you set off in the morning.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Rollochrome
Fort Worth, Texas
Posted: 11/20/21 11:16am Link  |  Quote  |  Print  |  Notify Moderator
Lots of good opinions here. I appreciated the feedback on this thread.
1999 Saved By Grace Alone Thru Faith Alone! Thank You Jesus!
2019 F-350 LWB 6.7 4wd XLT-FX4-3.31 on Michelin Defender LTX M/S
2022 3850BH Cruiser South Fork on Carlisle CSL 16
Page of 6
