RV.Net Open Roads Forum: Truck Campers: So many questions
 > So many questions
3 tons
NV.
Posted: 11/18/21 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
Everything seems backwards nowadays, so why not a camper??
3 tons
FireGuard
Frazier Park
Posted: 11/18/21 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
When he carries his motorcycle on a hitch rack it is covered
13Jeep Wrangler
07 Ragen 21FB
12 Yamaha Super Tenere
14 Suzuki DR 650
valhalla360
No paticular place.
Posted: 11/19/21 01:15am Link  |  Quote  |  Print  |  Notify Moderator
JKJavelin wrote:
It might make wheelies easier...
Assuming the center of gravity is over the rear axle, how would it make wheelies easier? Even if it's behind the axle, it's going to be by a small enough amount as to be largely irrelevant.
Only issues I see:
- Black paintjob will get hot in the summer.
- If driving in the rain, will the back wall with door stay water tight.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
bighatnohorse
Gig Harbor - Cave Creek
Posted: 11/19/21 07:16am Link  |  Quote  |  Print  |  Notify Moderator
A useful pass-through window and a shady place to sit outside.
blawless
Killaloe, Ontario
Posted: 11/19/21 09:38am Link  |  Quote  |  Print  |  Notify Moderator
He may be hasseled for being over length. The way around it would be to tow a utility trailer the same length as the overhang, to ensure he has taillights to the back of the rig. Problem solved with extra space to carry a dirt bike or quad for exploring.
Retired and enjoying it!
2005 Coachmen Aurora 3380 MBS Class A F53 V10 Banks Power System.
2014 Jeep Compass Toad
2001 Fleetwood Prowler 255B 5th wheel
2003 F150 King Ranch Supercrew 4X4
kohldad
Goose Creek, SC
Posted: 11/19/21 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
After experiencing a hail and rainstorm with 70+ mph winds directly into the rear of my camper without the rear door leaking, I'd have to say he is probably okay.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
Posted: 11/19/21 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
3 tons
Best response yet!
Definitely a "unique" setup...
2017 Heartland Torque T29
Chuck and Di
Yukon, Canada
Posted: 11/20/21 06:37am Link  |  Quote  |  Print  |  Notify Moderator
Based on the angle of the tie downs, best be gentle on the throttle and avoid steep hills.
jimh406
Western MT
Posted: 11/20/21 07:29am Link  |  Quote  |  Print  |  Notify Moderator
Simplest answer is usually the correct one. I'd say photoshop.
Other than that it was mounted in reverse because it wouldn't clear the cab.
covered wagon
Posted: 11/21/21 11:54am Link  |  Quote  |  Print  |  Notify Moderator
I would have had brackets made that allow using the front jacks to tilt the camper back out of the way of the cab. It just looks too strange the way it is even though it makes for cover in the event of rain.
 > So many questions
